Hi,
Hoping someone can help.
So I bought this belt from Euro Car Parts as it was the exact match for my reg.
http://www.eurocarparts.com/search/202779165
Took it to my mechanics today and he tried fitting it - turned out it was too long?
So I went back to ECP and they only had this one listed for the Accord. They suggested smaller options of the same belt.
I then took a 1749 (10mm shorter) and 1730 just in case. Both were too long. I then went back again and took 1715 which fitted ok but the pointer was not within the proper range on the plate behind the auto-tensioner pulley.
I should mention here the pointer was not in the proper range to begin with but wasn't far out. As ECP didn't have a smaller belt my mechanic sourced another (1700) from a local factor. The fit on this is a lot better and he's told me its safe to drive about. I have for the journey home etc and its been fine.
I haven't figured out how to post pics here yet but my concern is the 'proper range pointer' is slightly out still. There's a strip that pops out with a little square to the left of it. And the pointer points to the edge of the square box (further away from the strip that sticks out). The strip being the proper range indicator it should be in line with.
Any ideas if this is ok? or why its out of range and any thoughts as to why this many issues trying for the correct length. I thought it was only the Diesels that had a variation on belt length.
Thanks in advance
Thanks in advance
