Car is sluggish and ACC shows error
zsolt
Honda Accord 2011
Hi all, this is my first post here hope to see if anyone came across this fault before:
During a regular drive my Adaptive Cruise Control light went yellow and wouldn't activate, saying there is a fault. At around the same time the car became sluggish. It wouldn't accelerate as before, I am talking hardly any response on flooring the gas pedal. Could it be that the car went into limp mode? Are the ACC and sluggishness connected? What should I try to check first?
Any help would be greatly appreciated! Thanks!
First thing would be plug in a diagnostic and retrieve any error codes. That will signal towards the underlying issue.
I tried with a simple OBD reader but it didnt read any error codes. Do I need a more capable reader?
Yep, need to scan all modules. What year and engine is the car? Where are you located?
It’s a 2011, Diesel engine. I am in Oxford.
I’m probably a bit of a trek for you but try and get it on a garage level diagnostics if you can’t find someone with a Honda dealer system nearby.
I’ve never used this method of trying to retrieve a code.
