Driveshaft replacement
ryan14421
Hi all,
I replaced the passenger side without any issues. However on the drivers side I can’t seem to remove the old driveshaft. Where it connects to the intermediate shaft, it just won’t budge. Any ideas?
I'm about to change mine so hoping somebody has some tips. Did any transmission fluid leak out when you removed passenger side? Or did you drain it first?
I managed to do it in the end, just needs a good whack with a hammer and chisel to get it free. Passenger side was much easier using a crowbar leveraging between the axle and gearbox. No fluid was lost on either side. Hope that helps.
