Im wondering if anyone knows the torque setting for the oil pressure sensor on a h22a engine, usually found in 92-96 preludes but I think they are found in accords also. Im sure other variants of the h22 engine i.e. h22a7 etc are the same torque setting.
Its called oil pressure switch on this picture, but same thing and same torque setting. As you can see 18nm is about as much as you should do sparkplugs. Not much.
