Hose leak on engine
Channel Hopper
KT8 Postcode
Accord 7 Estate 2005
So, I have a small leak, from a small vertial pipe at the front of the engine. It's right in the centre and appears to be clamped on with a heavy spring circlip at the lower end, I can't see what is up top though without removing some bits.
Does Honda supply the original part or is it something I have to make up ?
Rats !
I took the pipe off (it is under 3" long and goes into the TRS EGR cooler above it). Unfortunately the pipe is OK but the outlet it bolts onto on the engine has corroded and only half remains.
I can't quite see if it is a removeable part.
