Nathjkent
Active Member
So I had the passenger front window switch disconnected today, when I plugged it back in the window went down all the way but now won't go back up, I thought maybe the switch was faulty but tried a spare and same issue, only down, so I even plugged a spare window motor in and same thing, will only go down, I've looked around online and it seems there's a reset procedure you can do but I've tried it multiple times and still no luck. I've disconnected the batter but that didn't work, I know there power there because you can hear the motor click when you press down on the window switch. Anyone got any ideas, can I reset the windows with diagnostic equipment? I have Aultel at work I could use.
Thanks in advance.
Mine a 2005 accord tourer
Thanks in advance.
