Hi
I have just done MOT and got the reverse light not working comment.
I checked the bulb and wiring, everything seems okay. Then, I went to check the reverse light switch, the switch is plugged into the transmission, but there is no cable connect to the switch. I searched everywhere to find the cable, but nothing to be found. There is no loose end that has a plug on it anywhere near that area. Its like the whole cable is missing.
Do you guys know where should I look?
Where is the other end of the cable located?
I don't wanna go to a mechanic to just reconnect the plug.
Appreciate any help.
