Hi CJM, it's not all the time I think it's only when accelareting fast (pressing the gas pedal hard) when I press the pedal normaly it will accelerate without any problems or if I take the foot of the pedal when cutin out and than continue pressing it slowly there is no problems. But last night I kept the pedal firmly pressed and the engine lost the revs and stopped, I had to wait 5 min then started the engine again that's when the engine management light came on. Today I wanted to take the car to a garage but the light disapeared (reset) it self.
Hi Rron,
Welcome along
Is it all the time ?
Just when cold ?
Does it go into limp mode?
Does it smoke a lot?
Have you had it serviced, by a Honda dealership?
Do you know whether the fuel filter has been changed (this is one of the biggest causes of problems) ?
( Garages often say they have replaced it but by doing a little search on here for fuel filter you will find many people who have had to change their fuel filter. The reason is the filter is quite tricky to replace, although there are some DIY guides on here showing you how to if you feel capable. )
It could be a few things so really we could do with some more detail on the situations it arises in.
[/quote]
