nick 9-5
So when I do my rear brakes where am I applying copper slip, obviously to the back of the pads, where else?
I didn't have any (so reused some of the old stuf behind the bellows that still looked clean).
...I thought all real men did that! :blush:Jon, do you also turn your boxers inside out to reduce the amount of laundry you have?
Also put it on the sticky out 'wings' (widest point of pad) that fit into the guides. But before doing that, check that the pad isn't an excessively tight fit in these guides - you may need to file/grind off the paint and/or casting marks to ensure that the pad is fre to move back and fro (but not too loose!!). I once thought I had a (another) siezed caliper, but it was actually just the pad jamming.So when I do my rear brakes where am I applying copper slip, obviously to the back of the pads, where else?
Your correct Bas copper grease will corrode the metal shims on the back of the pads.Use molykote, the black grease which is supplied on the pads, use copper grease only on the inner wheel so as it's easier to get the wheel off instead of them binding to the hub which can happen, ya know when ya gotta kick it off I've heard copper grease will bind the back of the pad to your caliper and end up ruining the calipers :unsure: :unsure:
