replied to you Natasha, just take a read of the ECU software and send it over, I'll check it out for you. No point changing an ECU if it's mapped, I can provide a stock file if it has been tuned.
And after that, swap the ECU, because it might be faulty.As already mentioned, blocked cat?
You're not still doubting that Natasha's real, are you? Really?If you're genuine do this...
She checked all that, and then swapped the engine.Truthfully I haven't read through all the posts, but I would want to check:
MAF
MAP
EGR
Injectors (and calibration)
High Pressure Pump
Turbo Charger/actuator
Cracked Manifold or leaking exhaust
Blocked Cat
Trust me, it's not your ECU. There is nothing to suggest your ECU is faulty.
It's a different engine in the car now, with same problem.My money is actually on incorrect injector calibration or a weak/non genuine MAF.
Was on Natasha's own list in her 3rd post hereI'm honestly not sure why anyone is thinking it's the ECU.
It's a bit difficult to tell without looking! Hard to imagine that it isn't related to the manifold being worked on recently (I should think you took it off completely to weld the crack?), so I'm guessing that a gasket has blown?Checked for leak today. We have some serious leak from exhaust manifold. That definitely was not there last week when were welding crack on that.
Any surgestions?
My opinion too.My opinion is that engine is over-fueled and excessive diesel gets in exhaust. The question is still open WHAT IS OVER-FULLING ENGINE? If all parts has been replaced?
BUT, MRS SHOUTY, YOU DIDN'T SAY IT WAS DIESEL, YOU JUST SAID IT WAS A LEAK!!!The whole point is WHY DIESEL IS IN EXHAUST MANIFOLD???
Mrs Shouty :lol:BUT, MRS SHOUTY, YOU DIDN'T SAY IT WAS DIESEL, YOU JUST SAID IT WAS A LEAK!!!
How the devil do you know there's diesel inside the exhaust manifold anyway?
But they welded up the cracked manifold! And they run a garage, so I'd ***ume it was done properly.There's probably neat diesel seeping out the cracked manifold
