Thanks guys for quick replay.Try search on ebay tonight.No,I don't have satnav
Has anyone on here done this setup?TypeR said:Make sure you run direct power line from battery to amp with a fuse inline. Running from cigarette lighter can cause a wire to burn in the loom. He amp draws a great deal of current.
With the right power cable that is and ground with a proper cable too.
