freddofrog
won 16.4k on Euro lottery :)
Is the Engine Mount Control system used on 7th gen, and if so is it only on the automatics ?
yeah that's what I'm talking aboutI ***ume you mean this: http://typeaccord.co.uk/forum/topic/10694-engine-mounts-how-cool-is-this/page__p__120145#entry120145 ??
If so, apparently it's on all petrol Accords, I believe the diesels use something different.
Part #9 might be the thing we're talking about ?
where does the fluid come from btw ?
that's what I would have thought, with an electrically operated switch that alters the hydraulic firmnessGood question. Since it's a sealed system, I ***ume the fluid is filled on fitting of the rubber mount.
you've lost me there, if it leaves the mount, it's goneWhat the valve does is simply close to prevent fluid from leaving the mount (locked) or open to allow fluid to flow freely.
I think that the "E" arrows are "external", whereas the "B" arrows are other "blocks" (the URL for the engine mounts contains "&block_02=B__4700", and B-48 in the diagram refers to the same URL but with "&block_02=B__4800", which is where that part B-48 can be found)If you take a look at the parts in the box marked E3, I think this is the fill point.
you've lost me there, if it leaves the mount, it's gone![]()
Ah, ok - thanks.I think that the "E" arrows are "external", whereas the "B" arrows are other "blocks" (the URL for the engine mounts contains "&block_02=B__4700", and B-48 in the diagram refers to the same URL but with "&block_02=B__4800", which is where that part B-48 can be found)
hey well done ....Ok, so with the B and E stuff here's the rest of the system:
http://www.lingshondaparts.com/honda_car_parts_selection_pfk.php?block_01=17SED01&block_02=E__0300&block_03=445
Learn something new each day! :lol:
my guess is that the vacuum suction alters the stiffness somehow.
another snippet from your original post ... "It switches between a setting optimized for damping vibration at idle, and another firmer setting"
at idle it will have max vacuum, so that is when it probably gets actuated, then gets switched off according to rpm and/or road speed
There is an electical solenoid on the wiring diagram that I have, which is what made me ask the question in the first place (and the EPS question too).So at idle, the mount will be at its softest at high-rpm it will be stiffest. So, thinking about this the vacuum must extract fluid or pressure to allow the mount to flex. At high RPM the vacuum is removed and the mount allowed to stiffen. Probably in a similar vein to the servo brake cylinder. I suppose to figure it out we'd need a diagram of the mount.
