Jump to content
...Another Tailgate Problem (Tourer)
  • Please log in to reply
51 replies to this topic
#41 Channel Hopper
Channel Hopper
    Advanced Member
  • Members
  • PipPipPip
  • 903 posts
  • Name:Stephen
  • Car :Accord 7 Estate 2005
  • LocationKT8 Postcode
Posted 20 May 2017 - 08:50 AM
right-click, save image as ....
then you can look at it at leisure outside of a browser
Thanks, I'll scour the Apple manual for hidden buttons later.
#42 freddofrog
freddofrog
    won 16.4k on Euro lottery :)
  • Banned
  • PipPipPip
  • 7,326 posts
  • Name:.Freddo
  • Car :TBD
  • LocationOff abroad
Posted 20 May 2017 - 12:27 PM
or get a platform that an Engineer would use to work with ;)
  • honda_saj likes this
#43 honda_saj
honda_saj
    Advanced Member
  • Members
  • PipPipPip
  • 1,152 posts
  • Name:sajeel
  • Car :honda accord
  • Locationlondon
Posted 18 July 2017 - 09:18 AM
did you fix tailgate looks like connector goes to ecu
Regards,
saj
#44 freddofrog
freddofrog
  • Banned
  • PipPipPip
  • 7,326 posts
  • Name:.Freddo
  • Car :TBD
Posted 18 July 2017 - 10:54 AM
I think #38 was a "fly by", his one and only post
#45 honda_saj
honda_saj
    Advanced Member
  • Members
  • PipPipPip
  • 1,152 posts
  • Name:sajeel
  • Car :honda accord
  • Locationlondon
Posted 18 July 2017 - 11:22 AM
Seems that way another flyby
Regards,
saj
#46 kingwowns
kingwowns
    Newbie
  • Members
  • Pip
  • 10 posts
  • Name:kingwowns
  • Car :Accord Tourer 2.2
  • LocationNotts
Posted 20 November 2017 - 06:45 PM
Hey guys - Had same issue as this thread.... Got some very welcome help from freddofrog in terms of plugging in diagnostics (ta!) BUT no obvious solution from other posts -
As we can reset whenever we need to by disconnecting the battery, I wondered - Is there a way I can put a switch into the power feed that goes to the ECU?  I'm getting tired of re-programming the radio :-)
#47 honda_saj
honda_saj
    Advanced Member
  • Members
  • PipPipPip
  • 1,152 posts
  • Name:sajeel
  • Car :honda accord
  • Locationlondon
Posted 21 November 2017 - 02:23 AM
Why would need to keep resetting ?
Regards,
saj
#48 kingwowns
kingwowns
    Newbie
  • Members
  • Pip
  • 10 posts
  • Name:kingwowns
  • LocationNotts
Posted 21 November 2017 - 11:19 AM
Hey Saj - Same reason as others - the boot tail warning light comes on then the boot won't open... Once we disconnect the battery for 10 secs it resets and works for up to a week...
#49 honda_saj
honda_saj
    Advanced Member
  • Members
  • PipPipPip
  • 1,152 posts
  • Name:sajeel
  • Car :honda accord
  • Locationlondon
Posted 21 November 2017 - 12:12 PM
You either have wiring issue or faulty ecu or software need update on tailgate ecu pm me if you still stuck
Regards,
saj
#50 honda_saj
honda_saj
    Advanced Member
  • Members
  • PipPipPip
  • 1,152 posts
  • Name:sajeel
  • Car :honda accord
  • Locationlondon
Posted 22 November 2017 - 06:47 PM
For those having tailgate issues I suggest you check wiring before jumping In too deep.
Since I repaired my boot wiring have never had to reset, you can remove tailgate fuse in engine to reset.
Regards,
saj
#51 kingwowns
kingwowns
    Newbie
  • Members
  • Pip
  • 10 posts
  • Name:kingwowns
  • LocationNotts
Posted 31 December 2017 - 02:33 PM
Thanks Saj!
UPDATE - Our battery was pretty ***** and finally died in the cold weather around a month ago - the problem has now not happened again, so perhaps before anything else, try a donor battery of good quality.
Ta
Chris
#52 honda_saj
honda_saj
    Advanced Member
  • Members
  • PipPipPip
  • 1,152 posts
  • Name:sajeel
  • Car :honda accord
  • Locationlondon
Posted 31 December 2017 - 06:02 PM
Thanks Saj!
Ta
Chris
The battery most likely reset which can fix ecu stuck issues. However if wiring has intermittent issues you will see problem back hopefully not in your case, thanks for reply.
Regards,
saj
