Had a quick look for a guide on doing this and could'nt find one so here goes, my 6th Gen is a Exec with climate control, however I have fitted a stereo in a standard Accord with the standard heater panel so I will advise on this also
Firstly this is what you are met with
It looks harder than it actually is, however its a fairly easy job
Firstly bring the steering wheel down as this gives better access to the screws, then remove the 3 screws at the top of the binnacle surround
Then remove the centre headlight adjustment switch as they're is a screw behind here that needs removing also, this can be a pain as it's fairly easy to scratch the surounding area, or break the front off the switch, I find using an old stanley knife blade wrapped in tissue paper worked a treat
Then remove the button for the odometer reset, this simply pulls off
Now remove the screw behind the headlight adjustment switch, I found it best to use a magnetec screwdriver as it stops the screw dissapearing in the dash once removed
Now is the most difficult part (especially if the surround has never been removed before) as it is held on with those retaining metal clips, just start at the top working your way around with light tugs, It will start to unclip
It is worth noting that it is especially tight below where the stereo is, I had to really tug on this part, whilst using a old credit card cut in half to help with leverage
Be caraful though as pull too hard and this can happen :blush:
Once the surround is loose, disconnect the hazard, Cruise control (if you have it) and fog light switches, there is a button on the plug, simply nip and pull, You can leave those switches in the surround once removed
