Yes it folds when you lock and unfolds when you turn ignition on. Its a custom made circuit made by previous owner. You to remember the non face lift 7th gen never came with Power folding mirrors so I retro fitted them. Even better is that the mirrors are Genuine JDM ones and not the usual UK specThe custom circuit for your mirrors being, that when you lock the car they auto fold?
Any links to this?
Ta.
interested, too, if it is an easy mod !
Dude i'd be interested in this. I want something that will switch my fog lamps on when unlocked, maybe even tap into the side lights. max 30 secs though with an LDR connected to only come on when its darkThis wouldn't be a hugely difficult circuit to build, it just depends on how you want the lights to behave?
For example, when the car is unlocked do you want to the lights to stay on for 30 seconds? do you want it to over-ride the light-switch on the dash?
At it's most basic, it's a 555 timer with an output relay connected to the front light relay.
Reason, I ask, is that I could probably throw together a circuit pretty quickly if you like and demo this.
Yes pretty much but for me i'd probably just wire to fog lamps so just need a 12v for 30 secs but triggered on unlock. Then when I open the doors the lights goes off.Ok, so the parameters are the following:
When unlocked AND it is dark, turn on the headlights and front fogs for 30 seconds max?
My fog lamps already don't work so easy to adapt. Not sure whats up with them but they don't turn on, the light comes on dash but no lights at lamps. I can bridge the connector and they turn on
Yes thought that so got some second hand relays which didn't work, could be duff relays too. The thing is the trigger signal only reads 3v when turned on at dash?Which connector? Is this not the relay problem in the front wheel arch?
See i got a normal relay and even that wouldn't kick in with the 3v signal. I had to send 12v and it turned on
Thats what I think but not sure where to start. The switch works and brings up the sign on the dash but the wire at relay which send the signal only reads 3v3V, you've a cable break or something, there should be 12V across the board.
where has this come from?here is coming/leaving home lights circuit fitted to 7gen, another circuit is operating folding mirrors, anyway this module is used mainly to use as DRL which use main beam lights at lower power.
don't know what else you want to know ;-)
didn't installed as I don't have it yet, I'll try to get it in february when I'll be in Poland and bring it here.
here's link for this module, good luck with google translator :lol:
http://allegro.pl/modul-swiatel-dziennych-drl-swiatla-dzienne-plus-i3830371949.html
