Jump to content
Accord Full LED Conversion - Bulb Guide - Courtesy of www.HorizonLEDs.co.uk
LED XENONS HID KITS CREE LED BULBS LED CONVERSION LEDS XENON HID
  • Please log in to reply
139 replies to this topic
#1 J4JAV
J4JAV
    Mr OCD Detailing
  • TA Friends
  • PipPipPip
  • 1,512 posts
  • Name:J4JAV
  • Car :Accord CL7 & ATR
  • LocationWest Yorkshire
Posted 20 February 2014 - 01:29 PM
After a few questions and requests, and being the owner of a 7th Generation Accord I have written you all a guide to follow in case you want to convert your Accord's bulbs to LED. Admin you can pin this up if you wish so its easier to find for everyone! Thanks
Right Guys,
Below is the compete list of what bulbs the 7th Generation Accord 2003-2008, takes if your looking to do a full LED conversion like myself. I believe the 8th Generation Accord is very similar if not then the same. I am sure Brett will be able to confirm with us all. Please note that you don't need any CANBUS bulbs unless you like a particular bulb which only comes in a CANBUS model.
Interior LED Lights
  • Front Courtesy Lights = x2 31mm LED Festoon Bulbs
Link - PURE WHITE
  • Rear Courtesy Light = x1 31mm LED Festoon Bulb
Link - PURE WHITE
  • Driver & Passenger Door Cards = x2 501/T10/W5W Wedge LED Bulbs
Link - PURE WHITE
  • Glove Box & Boot Light = x2 501/T10/W5W Wedge LED Bulbs
Link - PURE WHITE
  • Vanity Mirrors = x2 Special Sized Festoon LED Bulbs (we don't stock these yet, but if there is demand for them from Accord owners then I will get them)
Exterior LED Lights
  • Front Sidelights = x2 501/T10/W5W Wedge LED Bulbs (the Accord has a lot of room in its headlamps so you could go for a longer bulb as in the link - more light output)
Link - PURE WHITE
  • Front Indicators = x2 7440 Wedge LED Bulbs (if you want them to be seen I recommend going for CREE LED bulbs - I have tried and tested both)
Link - AMBER - we have a choice of 5W, 16W, 30W and 50W, I personally use 30W in mine, you will also need resistors for these to fix the fast flashing, I am still to add the resistor packs to our website, will update the thread with the link soon.
  • Rear Indicators = x2 7440 Wedge LED Bulbs (if you want them to be seen I recommend going for CREE LED bulbs - I have tried and tested both)
Link - AMBER - we have a choice of 5W, 16W, 30W and 50W, I personally use 50W in mine as they are important bulbs, you will also need resistors for these to fix the fast flashing, I am still to add the resistor packs to our website, will update the thread with the link soon.
  • Rear Sidelights (the two bulbs fitted within the boot lid) = x2 501/T10/W5W Wedge LED Bulbs (you can only fit the ones in my link, limited space here)
Link - RED
  • Rear Brake/Tail Lights = x2 7443 LED Bulbs (if you want them to be seen I recommend going for CREE LED bulbs - I have tried and tested both)
Link - RED - we have a choice of 5W, 16W, 30W and 50W, I personally use 50W in mine as these are important bulbs.
  • Third Brake Lamp/Middle Brake = x1 7440 LED Bulb (if you want them to be seen I recommend going for CREE LED bulbs - I have tried and tested both)
Link - RED - please only go for the 5W Retro/16W option due to the design of the housing, the 5W Retro and 16W disperses the best light output in full 360 degrees.
  • Reverse Light = x1 7440 LED Bulb (if you want them to be seen I recommend going for CREE LED bulbs - I have tried and tested both)
Link - WHITE - I use the 50W in mine because it actually helps with reversing at night, that said the 16W and 30W is better than the factory fitted ones, I have smoked rear tints so hence why I use the 50W.
  • Rear Fog = x1 7440 LED Bulb (if you want them to be seen I recommend going for CREE LED bulbs - I have tried and tested both)
Link - RED - I used the 30W in mine, as the design of the actual Accord's rear fog has a built in projector so helps with better light output, although you could go for the 16W or even the 50W!
Xenon/HID/Fog Solutions
  • Front Dipped Beam = H1 Xenon HID Conversion Kit either 35W or 55W, you don't need CANBUS. 55W is slighter better and brighter and goes a much longer distance. Colour temperatures are 5000K, 6000K, 8000K, see the link for more details about this. I use 6000k as it matches better with the side light LEDs as the Accord even has the blue tint on the headlamp housing.
Link - if you really want to go all out then the Fast Start Slim Kit is our latest one. Fast start simply fires up and gives full brightness within 3 seconds, so like your OEM BMW, Audi, Mercedes etc... traditional HID kits will always have a slight warm up period of around maximum of 30 seconds, which is normal for them.
  • Main Beam = H1 Xenon HID Conversion Kit either 35W or 55W, I would not suggest it because they are not suitable for flashing, because of the warm up time. Even if you want to go for the fast start kit, it will soon die with all the flashing as the ballasts are not designed for that. I would stick to 55W high quality halogens such as Philips/Osram. Unless you use your main beam a lot (constantly on - country roads) then it is possible to fit Xenons, just buy two HID kits.
  • Front Fog Lights = H11 Xenon HID Conversion Kit 55W or 50W Cree LED Bulbs - I have Xenons in mine as they are better and act more like fog lights but you can also fit H11 Cree LED bulbs in them, depends on your choice wether you want purpose or style. Both links below.
Link - PURE WHITE Cree LED
or
Link - Xenon HID Kits 35W/55W (55W is ideal for fog lights)
Right thats the complete list for the Accord, if I have missed anything then let me know, please note that the indicators on the 7th Generation Accord are already LED. If you want to do a full conversion then just go through the list and add them to the basket as you go along, even if you don't want a full conversion you can still do the same with the bulbs which you do want, that way you won't be confused and keep having to come back & forth and checking etc... Please be vary of any stock delays, and remember that all bulbs apart from CREE LEDs are sold in pairs.
Any questions then please ask me on this thread, or drop me and email at Info@HorizonLEDs.co.uk. Check out our other products at www.HorizonLEDs.co.uk, remember you get 10% off all orders and free delivery over £50!!!
Thank you!
  • HuskyMan, Blue2, dynacord and 1 other like this
www.HorizonLEDs.co.uk | Automotive Lighting Specialists
Please like us on Facebook!
#2 Tomas44
Tomas44
  • TA Friends
  • PipPipPip
  • 1,808 posts
  • Name:Tomas
  • Car :Honda Accord i-CTDi
  • LocationLondon
Posted 20 February 2014 - 03:33 PM
I want to put led bulbs for indicators,but not sure how to connect resistors.Is it they gona be expensive?
18 inch Ultralite ATECH wheels,Eibach Pro Springs,Tint front Lights,6000k Hid kit,Parking sensors with screen,Heko windows deflectors,Roof spoiler,Ingalls rear camber,Red OEM badges,Full body kit,Pager alarm system,xcarlink, Sport Pedals,Skunk2 gear knob,Short Shifter,Led inside,Interior wrap with carbon vinyl,Bose Front door speakers,Rear Pioneer speakers,Custom Stainless Steel Exhaust from Powerflow,Stage 1 EGR Off blocked with plate by Premier Tuning
#3 HuskyMan
HuskyMan
  • TA Friends
  • PipPipPip
  • 1,722 posts
  • Name:Trev
  • Car :57 Tourer i-CTDi EX
  • LocationHavant
Posted 20 February 2014 - 04:18 PM
Awesome thanks, Jav.
Any differences for a tourer?
Trev, Husky rescuer.
57 plate Honda Accord Tourer i-CTDi EX (Nav+HFT). Stage 1 Premier Tuning EGR OFF. 5000K HIDs. Blue/white LED interior.
#4 J4JAV
J4JAV
    Mr OCD Detailing
  • TA Friends
  • PipPipPip
  • 1,512 posts
  • Name:J4JAV
Posted 20 February 2014 - 05:14 PM
Hi Trev, tourer is the sam from what I remember, as an ex member with a tourer did the same conversion as me a few years back!
#5 J4JAV
J4JAV
    Mr OCD Detailing
  • TA Friends
  • PipPipPip
  • 1,512 posts
  • Name:J4JAV
Posted 20 February 2014 - 05:16 PM
Hi Tomas, the resistors are very simple, you will need one for each indicator. So if your doing x4 indicators then x4 resistor packs, they come in pairs anyway. They will be priced up and added to the website this evening, off the top of my head they should be around £5-10 for a pair and they come with the connectors... I will find you a pic, they are very simple to fit, 2 minute job!
#6 J4JAV
J4JAV
    Mr OCD Detailing
  • TA Friends
  • PipPipPip
  • 1,512 posts
  • Name:J4JAV
Posted 20 February 2014 - 05:24 PM
these are the resistors, very similar to these and thats how they come as a pair...
ScreenShot2014-02-20at090106_zps9af4f6ca
and this is how they are fitted, in parallel to your indicator wiring, very simple! mine have been fitted like this for 3 years and I have not had a single issue with the resistor or the CREE LED bulbs...
ScreenShot2014-02-20at171701_zps6dfdb007
#7 J4JAV
J4JAV
    Mr OCD Detailing
  • TA Friends
  • PipPipPip
  • 1,512 posts
  • Name:J4JAV
Posted 20 February 2014 - 05:31 PM
actually it was 4 years ago! lol I am still running these same bulbs and I use the car nearly every day, the car looks so different with the old wheels and the old kit lol
here is the YouTube video!
Edited by J4JAV, 20 February 2014 - 05:32 PM.
#8 J4JAV
J4JAV
    Mr OCD Detailing
  • TA Friends
  • PipPipPip
  • 1,512 posts
  • Name:J4JAV
Posted 20 February 2014 - 05:32 PM
#9 J4JAV
J4JAV
    Mr OCD Detailing
  • TA Friends
  • PipPipPip
  • 1,512 posts
  • Name:J4JAV
#10 Tomas44
Tomas44
  • TA Friends
  • PipPipPip
  • 1,808 posts
  • Name:Tomas
  • LocationLondon
Posted 20 February 2014 - 06:34 PM
Thanks,mate for explaining.I make oder latter.
#11 J4JAV
J4JAV
    Mr OCD Detailing
  • TA Friends
  • PipPipPip
  • 1,512 posts
  • Name:J4JAV
Posted 20 February 2014 - 06:56 PM
Okay, I will let you know when the resistors have been added to the site. currently working on this and stock is on the way of both CREE LEDs and resistors!
  • Stevie91 likes this
#12 Tomas44
Tomas44
  • TA Friends
  • PipPipPip
  • 1,808 posts
  • Name:Tomas
  • LocationLondon
Posted 20 February 2014 - 06:57 PM
Ok,thanks.
#13 Uncle_Gravy
Uncle_Gravy
  • Members
  • PipPip
  • 88 posts
  • Name:Uncle Gravy
  • Car :2004 3.0i BMW Z4
  • LocationS.E Wales
Posted 21 February 2014 - 12:20 PM
I fancy changing the Number Plate lights, you have a few LEDs which I don't know what the difference is between them all, So what would you recommend?
#14 J4JAV
J4JAV
    Mr OCD Detailing
  • TA Friends
  • PipPipPip
  • 1,512 posts
  • Name:J4JAV
Posted 21 February 2014 - 05:59 PM
Hi, for the number plates you need T10 bulbs, preferably in WHITE, unless you have a show car  :P
Here is the link for the Accord - others are slightly larger and have greater light output but you can't fit these into the Accord's number plate light housing...
http://www.horizonle...?product_id=159
You will get away with these ones too, although it will be a slight tight fit... though they will fit... the edge of the bulb will touch the housing but as they are LED with no heat, it won't be an issue!  :D
http://www.horizonle...?product_id=160
#15 Uncle_Gravy
Uncle_Gravy
  • Members
  • PipPip
  • 88 posts
  • Name:Uncle Gravy
  • LocationS.E Wales
Posted 24 February 2014 - 09:51 AM
Cheers for that, I may be in touch soon.
#16 J4JAV
J4JAV
    Mr OCD Detailing
  • TA Friends
  • PipPipPip
  • 1,512 posts
  • Name:J4JAV
Posted 24 February 2014 - 10:59 AM
No problem mate. thanks
#17 Stevie91
Stevie91
    Newbie
  • Members
  • Pip
  • 14 posts
  • Name:Stevie
  • Car :Civic Coupe
  • LocationIreland
Posted 24 February 2014 - 09:50 PM
Hi mate handy topic thanks. Looking to order some sidelight LEDs off you. Just confirming, are they a pure white? Ones I have ordered all look blue at night even in pre facelift headlights. Cheers
#18 J4JAV
J4JAV
    Mr OCD Detailing
  • TA Friends
  • PipPipPip
  • 1,512 posts
  • Name:J4JAV
Posted 24 February 2014 - 10:07 PM
Hi Stevie,
All our Pure White ones are 6000K, they are designed to match our HID Kits. All I can suggest is you can try them and if they are not up to your standards you can return them under our 7 day policy.
Although they are pure white and have not got any hint of blue in them :-)
#19 r3dd3v1l
r3dd3v1l
    Advanced Member
  • Members
  • PipPipPip
  • 405 posts
  • Name:Asher
  • Car :Honda Accord EX
  • LocationGloucester
Posted 25 February 2014 - 10:12 AM
is there a page like this for 8th gen accords?
#20 J4JAV
J4JAV
    Mr OCD Detailing
  • TA Friends
  • PipPipPip
  • 1,512 posts
  • Name:J4JAV
Posted 26 February 2014 - 08:10 AM
Hi Asher, from what I am aware the 8th Gen Accord is the exact same!  :)
If you PM Brett, he will be able to conform 100%, he has had both 7 & 8th Gen.
Also tagged with one or more of these keywords: LED, XENONS, HID KITS, CREE LED, BULBS, LED CONVERSION, LEDS, XENON HID
