Nightwalker
Hello,
I'm getting a P0606 ecm/pcm internal circuit malfunction fault coming up all the time. When I say all the time I mean it comes on for a day or so then goes out for a day or so. This has been happening for around 3months now, sometimes it stays off for longer but always comes back.
I know the code because a friend used his Autel Maxi Diag reader on the car, it has been deleted but keeps coming back.
It also comes up with this...ABS/VAS will quit communication above 50k/30MPH...which I have no idea what it means. The ABS light has never come on so I have no idea what the problem is there. Can't be that bigger deal presumably.
Basically the car drives perfectly normally and I haven't had a single issue with it in any way...accept the damn engine light comes on n off for these faults. I get the impression it isn't a major deal and it has been mentioned they could be glitches or merely a loose connection or wire.
Any ideas??
Any ideas??
