Few questions on maintenance?
NimBoy
United Kingdom
Honda Accord 2.0SE
I am due a major service for my 2002 2.0 Accord
What are the main things it needs changing?
Oil & Oil Filter
Spark plugs
Fuel Filter
Cabin filter
is there anything else you can add to this list ?
is there an aftermarket exhaust available for the Accord 2002 ? (any link to it)
When was the cambelt and tensioner replaced? (perhaps could be time to change it) water pump should be replaced too
Other things could be:
- Brake fluid? (when was it last replaced - Brake fluid takes on water over time hence why they brake feel becomes spongy)
- Transmission fluid change
- Strip and re-grease brake callipers (slider pins)
- Coolant change (when was it last done?) May be worth to change it if it hasn't been done in a while
Where you based? (this place is in Orpington in kent)
Best place I know for after market custom made exhausts are these guys.
Very well known in the Honda tuning scene and a lot of people use them.
My brother had his exhaust made by them and it is first class quality
http://solid-fabrications.co.uk/
Some examples of his Honda work
civic
http://solid-fabrications.co.uk/aaron_civic.html
Euro r
http://solid-fabrications.co.uk/euror.html
S2k manifold
http://solid-fabrications.co.uk/honda_s2000.html
The system on that civic is first class - really subtle exhaust tip and apparently it was a really quiet exhaust system
The mileage is 36K,
I will have the following done on the car
Oil & Oil Filter
Air filter
Spark Plugs
Fuel Filter
Change the transmission oil
Flush Coolant and put in new coolant
Brake Fluid
Missed Anything ?
What is the best lubricant for the hinges ? (any recommendation)
