windscreen washers
mikem
Lancashire
accord
Hi, windscreen washers have died. No motor/pump sound and cannot work out which fuse it may be?
cannot even see where it is?
any advise welcome.
Had a look ont'net and it looks like the pump is on the bottom part of the storage bottle?
thought must be pump so ordered one but tonight with headlights on the headlight washers work, but not the windscreen. There cannot be 2 pumps surely????????????
I had same problem when I bought my car 8 weeks ago, cut a long story short there is 2 pumps, the windscreen washer pump is the lower one on the rhs of the car, I bought a Chinese one one eBay for £3.50 and it works perfect. You need to pull out the drivers side of the front bumper to get in at it, follow the excellent guide on this forum on bumper removal then just ease drivers side out a bit.
But check the fuse is OK first, fusebox is tucked down under drivers side dash low down at the side. I can't remem what fuse it is, use Google.
Good luck,
Bob
