Accord Sat Nav DVD Tray
johnny 5
Heathrow
Accord Type-S
I was wondering of those who have Sat Nav, can someone measure the height and width of the dvd drive opening on the center console trim? as in open the flap and you are left with a hole and the sat nav dvd drive...I want to check if it is possible to place an aftermarket headunit behind that flap so it is hidden and OEM when parked up :) Thanks!
Hi
did you manage to put single DIN in place of DVD?
And if so, where did you put DVD?
nixon1974 said:
Hi
You can yes. I have installed a single din unit in the same place as the nav DVD drive, the aftermarket radio had a large knob on it so the flap on the drawer had to be removed also but it fits nice. In my case I removed the factory nav display/climate premium and replaced it with a standard premium/climate set to retain the climate controls therefore not needed the nav drive anymore. If you just disconnect the nav drive the factory screen will go blank.
