skinnyman
Car - 2006 2.4 Type S
So, driving down the M1 earlier and the VSA and engine management light comes on, and the car starts to stutter when lifting off the throttle, then went into limp mode, no power when accelerating. So I pulled over when I could and turned the engine off. After turning it back on the VSA light went out, but the engine management light remains on. It's now out of limp mode too. It's now driving fine again, with the VSA light gone, but the management light is still there.
I've had a search and anything VSA related seems to involve the light remaining on, so hoping this is a different issue.
So, any ideas?
Edit - Can this be ***ociated with battery issues in any way? I've just checked and there's what can only be described as white gunk on both battery terminals, fresh wet gunk too. I've read that this doesn't necessarily means it's dying, but I've never seen it on previous cars.
Edit no.2 - Just took it for a drive around the block to see if the VSA light would come back on with some speed. The brakes felt a little soft, so I took it down the main road and did some hard accelerating and braking. Accelerates just fine, and then after a few harsh braking attempts the engine management light disappeared, and the brakes are back to normal. So now the car is driving fine again.
What the hell is going on?!?
So, any ideas?
