This just happened to me. Luckily my car is on LPG and I can start it on LPG, although not recommended...
I have just tested the main relay, and it seems to be working: I put the multimeter leads in the wires that goes to the fuel pump, and the they make contact when you turn on the ignition for 2 seconds, which is the right behavior...
Then I shorted-fused those two wires, and it's supposed to hear the pump, but nothing happened..., which is a bad sign...
I just have to make another test on the fuel pump itself, but didn't had the chance to do it. The access to the fuel pump is through the trunk, you have to remove all the floor panels, and you see it, behind the rear seats.
The main relay is easily tested. Take at the following pdf, on page 6 you can see how the relay can be tested.
http://www.pdf-archive.com/2014/11/08/fuel-pump/
Oh, BTW, to access the main relay, lay down under the steering wheel and look up. It's a plastic box, attached to a metal bracket. The metal bracket is bolted somewhere near the steering column, it's near the brake pedal switch.
