hornyhonda
Does anyone know the torque settings for the 4 nuts on the rear hub? I recently replaced the abs sensor as some of you know and in doing so I removed the hub to get the old sensor out. I just want to be sure ive done it tight enough as I read something about wheel bearings going bad if the hub nuts arent torqued correctly.
