Jump to content
noise setting off
  • Please log in to reply
21 replies to this topic
#1 Kingy91
Kingy91
  • Members
  • PipPip
  • 67 posts
  • Name:Philip Michael
  • Car :2.0 vtec 08
  • LocationUnited Kingdom
Posted 20 February 2015 - 05:07 PM
My car makes a noise when i set off. Not all the time but say 6/10. Its like a low pitched squeeling noise. Does anyone know anything about this? Do the 2.0 petrol engines have dmfs?
#2 Draga
Draga
    Advanced Member
  • Members
  • PipPipPip
  • 120 posts
  • Name:Harpreet S bassi
  • Car :CL9
  • LocationLondon
Posted 20 February 2015 - 05:09 PM
is it a more of a grunting noise but very low noise?
#3 Kingy91
Kingy91
  • Members
  • PipPip
  • 67 posts
  • Car :2.0 vtec 08
Posted 20 February 2015 - 05:10 PM
Im not sure really how to explain it. It happens in the middle of releasing the clutch though so im guessing its clutch/flywheel related. Only happens setting off never changing gear.
#4 brett
brett
    T A Terminator
  • Administrators
  • 13,669 posts
  • Name:Brett
  • Car :8th gen 2.4 Manual
  • LocationBristol
Posted 20 February 2015 - 05:11 PM
No DMF on petrol accords.
This might be a pully or belt making the noise
 photo IMG_06551_zps16877260.jpg photo 1a30ead12b5799ee4c7f519123a797de_zps2vsu5cen.jpg
#5 Kingy91
Kingy91
  • Members
  • PipPip
  • 67 posts
  • Car :2.0 vtec 08
Posted 20 February 2015 - 05:13 PM
You may well be right.Which pulley if any do you think would be most likely?
#6 brett
brett
    T A Terminator
  • Administrators
  • 13,669 posts
  • Name:Brett
  • LocationBristol
Got you I have the same on mine it's the clutch release bearing running dry.
My car is on 55k and started doing this about 5 k ago but 7th accords have the same problem and go on with no problem at all
#7 Kingy91
Kingy91
  • Members
  • PipPip
  • 67 posts
  • Car :2.0 vtec 08
Posted 20 February 2015 - 05:16 PM
Ah right. Mines just turned to 57k miles. Anything you can do to grease/oil them? I know there in the bell housing so highly unlikely you can. Ive only had the car 2 weeks and have booked in for them to have a look. I just want the best idea possible so they dont try fob me off.
#8 brett
brett
    T A Terminator
  • Administrators
  • 13,669 posts
  • Name:Brett
  • LocationBristol
Posted 20 February 2015 - 05:19 PM
TBO it's not worth messing with IMO as the work involved to replace the bearing you might as well have a new clutch.
If the work is being done free of charge on warranty then go for it
#9 Kingy91
Kingy91
  • Members
  • PipPip
  • 67 posts
  • Car :2.0 vtec 08
Posted 20 February 2015 - 05:22 PM
I'll see where i get. I know a clutchisn't generally a warranty item but with me just getting the car I'll try my luck!
#10 Draga
Draga
    Advanced Member
  • Members
  • PipPipPip
  • 120 posts
  • Car :CL9
  • LocationLondon
Posted 20 February 2015 - 05:24 PM
i hope i am not thread stealing and the op doesnt mind me saying this but could some one let me know if the cl9 2.4 exec accords also have the same issue i started having this issue at 95k :$ i am thinking of replacing the whole clutch
#11 brett
brett
    T A Terminator
  • Administrators
  • 13,669 posts
  • Name:Brett
  • LocationBristol
Was the car brought from a main dealer?
If so they should change the bearing free of charge and might put a new clutch in for good measure
#12 brett
brett
    T A Terminator
  • Administrators
  • 13,669 posts
  • Name:Brett
  • LocationBristol
Posted 20 February 2015 - 05:25 PM
I'm sure all the accords suffer this tbo
  • Draga likes this
#13 Kingy91
Kingy91
  • Members
  • PipPip
  • 67 posts
  • Car :2.0 vtec 08
Posted 20 February 2015 - 05:29 PM
No it was bought from a local used car supermarket. They are normally very good and change anything to return tyethe car to perfect condition. If i say the release bearing is knackered they may do the clutch for me. Without a mechanic test driving it much its not exactly an easily noticeable problem. And no problem at all mate, you've asked a question relevant to the thread.
#14 brett
brett
    T A Terminator
  • Administrators
  • 13,669 posts
  • Name:Brett
  • LocationBristol
Posted 20 February 2015 - 05:32 PM
Great if they do change it and good luck.
A way to test it is if you slighty ride the clutch on a quick gear change from 2nd to 3rd with lots of revs.This is when mine does it.
#15 Kingy91
Kingy91
  • Members
  • PipPip
  • 67 posts
  • Car :2.0 vtec 08
Posted 20 February 2015 - 06:33 PM
Ive just beenround to a mates who is an experienced mechanic. Hes ruled out clutch slip. Its just something like rust on the flywheel. When he drove it his way it didn't do it but because ive come from diesel's and think you need to rev petrols it does make that noise.
#16 brett
brett
    T A Terminator
  • Administrators
  • 13,669 posts
  • Name:Brett
  • LocationBristol
Posted 20 February 2015 - 07:05 PM
You won't get clutch slip with a dry bearing only the very faint sweak
#17 Kingy91
Kingy91
  • Members
  • PipPip
  • 67 posts
  • Car :2.0 vtec 08
Posted 20 February 2015 - 07:09 PM
Yeah i know mate its just ruling stuff out to narrow down possible causes :)
#18 TypeR
TypeR
    Iron Man
  • Administrators
  • 5,881 posts
  • Name:Honda Guy
  • Car :Accord 05 Exec cdti
  • LocationWest Yorkshire
Posted 21 February 2015 - 12:11 AM
Sounds like clutch release bearing has gone dry. Very common on accords
Honda Accord 2.2 I-CTDI Executive with Premier Tuning Stage 1 EGR OFF 18" Storms, LED number plate lights, LED sidelights, HID 4300K and X carlink with bluetooth handsfree. Diesel Power
#19 Peterbfd
Peterbfd
    Advanced Member
  • Members
  • PipPipPip
  • 122 posts
  • Name:Peter Corfield
  • Car :8th Gen GT
  • LocationBradford
Posted 21 February 2015 - 04:23 PM
I get a noise setting of as well although mine sound like someone blowing down a pipe, quite a deep noise.
I would not call it a squeak.
If this the same problem ?
#20 Drejc112
Drejc112
  • Members
  • PipPip
  • 15 posts
  • Name:Andrej
  • Car :Honda Accord 2012
  • LocationSlovenia
Posted 07 February 2019 - 09:02 AM
Same here, sounds something like clutch bearing to me too, only when takeing of just before the clutch fully bites...
What to do ? Can i leave it or does it need a fix ?
Mine is CU1 facelift ,2012 .
Edited by Drejc112, 07 February 2019 - 09:36 AM.
