Hi guys,
While driving last night I noticed something unusual. I drove from Bolton To Manchester and then onto Glossop, no issues. I then drove back by which time it was absolutely freezing (about 1 degrees outside with freezing rain) Just as I was coming off the motorway I thought that the temp gauge had dropped slightly.Watching it, within minutes it had almost gone down to zero. Engine was running fine though. I turned the heating off and the needle slowly rose back up to about quarter way.
As I said engine /car ran fine throughout. The gauge has always been constant, sitting just below the halfway mark no matter what the conditions. I've checked the coolant and that's fine so my first thought is a stuck open thermostat?
Anything else I should check? And best place to buy a thermostat and any recommendations?
Thank you
Thank you
