Jump to content
car battery changed, key fob not working
key fob
  • Please log in to reply
5 replies to this topic
#1 TheJamMod
TheJamMod
    Advanced Member
  • Members
  • PipPipPip
  • 267 posts
  • Name:Dharms
  • Car :Accord
  • LocationWest Mids
Posted 14 January 2016 - 12:29 PM
Just had the car battery changed and now the key fob is not doing anything. If I unlock the car manually, it only opens the driver door and car alarm goes off.
Do I need to recalibrate the fob with the car? I know one fob key needs a battery change, but even the spare key does not unlock the car.
#2 TheJamMod
TheJamMod
    Advanced Member
  • Members
  • PipPipPip
  • 267 posts
  • Name:Dharms
  • Car :Accord
  • LocationWest Mids
Posted 14 January 2016 - 03:21 PM
I changed the battery on the master key. It's working now. I'll do the same with the spare key
In case the key fob loses sync with the car, this is what you do:
1. Sit in the car with all doors/bootlid tightly closed
2. Turn the key to the ON position, marked by "II" on the ignition bezel so the dash lights come on, then within 5 seconds press the "Lock" button on the remote for 1 second or so and release the button.
3. Turn the key to the OFF position, marked by "I" on the ignition bezel - dash lights go off.
4. Repeat steps 2 & 3 three more times (A total of 4 times) - each step must be done within 5 seconds of the previous step.
5. Upon the 4th turning of the key to "ON", press the lock button on one remote, the locks will make a cycling sound (clunk), locks will NOT lock or unlock at this point, they will just make a noise. The system is now in programming mode. Do not turn key off.
6. Within 5 seconds of entering programming mode and within 5 seconds of each other, press the lock button ON EACH remote you are programming, for a second or so and release. This step needs to be completed within 10 seconds. Each time a remote button is pushed, the locks should cycle. Up to 3 remotes can be programmed.
7. Turn ignition completely off and remove the key. Step out of car and close door. The remotes should be programmed and should work. If you have a bootlid/hatch release, the button for this feature needs to be held for a few seconds before the bootlid/hatch will "pop".
  • f2raf and honda_saj like this
#3 s-preston87
s-preston87
  • Members
  • PipPip
  • 39 posts
  • Name:Sanj
  • Car :Accord Sport
  • LocationLancashire
Posted 24 December 2018 - 12:19 AM
Hi pal,
Some home I have managed to accidently clear the programming from my left on for a accord 2005 sport.
I have completed the full programming steps and this have worked fine for the remote lock/ unlock but for some reason the boot release from the fob no longer works.
IS there anything else i need to do in order to enable the boot release on the fob?
#4 TheJamMod
TheJamMod
    Advanced Member
  • Members
  • PipPipPip
  • 267 posts
  • Name:Dharms
  • Car :Accord
  • LocationWest Mids
Posted 29 December 2018 - 03:03 PM
Have you changed the batteries?
Was it working before the battery change?
Tried the spare key?
#5 honda_saj
honda_saj
    Advanced Member
  • Members
  • PipPipPip
  • 1,146 posts
  • Name:sajeel
  • Car :honda accord
  • Locationlondon
Posted 01 January 2019 - 04:39 PM
i have programmed many times and boot release works straight away can you open boot manaully and close using button on boot ?
Regards,
saj
#6 Morrisey
Morrisey
  • Members
  • PipPip
  • 34 posts
  • Name:Paul
  • Car :Honda Accord
  • LocationWales
Posted 12 January 2019 - 05:24 PM
Did you manage to get this fixed? How? I'm in the same boat, with no boot open/close function via key fob. Everything else works, including central locking via key fob.
Also tagged with one or more of these keywords: key fob
