Goodluckmonkey
TA Friends
Use the headlamp removal guide to remove the offside headlamp. (Undo Phillips screw in each arch, remove plastic front panel trim, pull out top of front bumper, 4 bolts in each headlamp)
Undo the bolt holding the top of the washer bottle in, and pull the top out.
Undo the aircon line to front panel bracket and remove.
Undo the two bolts holding in the VSA guard bracket. Remove pipe clips.
Pull the guard bracket out and sling it on the floor in disgust.
