Hi guys,
Noob here. Have read through the varying and many Boot problem thread on here but not finding a solution to my problem so thought I would post my exact issues hoping for a pointer in the right direction.
Honda Accord Tourer 2004 UK Model
Only had it 6 months and since I had it the automatic opening/closing has never worked but that never bothered me as the exterior handle popped the boot fine.
Maybe coincidence but had to replace battery about 3 weeks ago as it simply died.
4 Days ago. NO BOOT. Was sudden, wasnt intermittent just went completely with no warning.
Thought I would try the ECU reset I see mentioned but I see so many different ways people say to do it?!?!?!?
How should I do the ECU reset please?
I tried by completely disconnecting battery for 15mins. This results in the boot opening ONCE. As soon as you close it again you are back to square one unless you disconnect battery for ages again??
As it will open after a battery disconnect I ***ume that wiring and actual boot exterior handle/switch are fine so possible ECU screwed or needs a better reset than I am doing.
Have checked fuse also fine.
Thanks in advance for any advice. Much appreciated.
