Jump to content
Clutch pedal
  • Please log in to reply
9 replies to this topic
#1 honda_saj
honda_saj
    Advanced Member
  • Members
  • PipPipPip
  • 1,154 posts
  • Name:sajeel
  • Car :honda accord
  • Locationlondon
Posted 27 April 2016 - 09:38 AM
Quick question is the clutch pedal for petrol and diesel the same I know there is two types of clutch pedal one with one sensor and another with two sensors.
Can the diesel one fit into petrol car my assumption is they are the same ?
Sent from my SM-G901F using Tapatalk
Regards,
saj
#2 freddofrog
freddofrog
    won 16.4k on Euro lottery :)
  • Banned
  • PipPipPip
  • 7,326 posts
  • Name:.Freddo
  • Car :TBD
  • LocationOff abroad
Posted 27 April 2016 - 10:07 AM
looks like the brake pedal is the same part number, but not the clutch pedal, although that doesn't totally prove clutch pedals are incompatible
2004 2.4 exec
https://www.lingshon...56&block_05=hcr
2004 2.2 exec
https://www.lingshon...48&block_05=hcr
  • honda_saj likes this
#3 honda_saj
honda_saj
    Advanced Member
  • Members
  • PipPipPip
  • 1,154 posts
  • Name:sajeel
  • Car :honda accord
  • Locationlondon
Posted 27 April 2016 - 11:48 AM
Hi freddofrog
Hope all is well,
I see that from lings website, have got a diesel clutch pedal to fit to petrol 2.4 looks the same except has thread nut for two switches as compared to 1 on petrol so should fit and work just fine, will update after fitting.
  • freddofrog likes this
Regards,
saj
#4 honda_saj
honda_saj
    Advanced Member
  • Members
  • PipPipPip
  • 1,154 posts
  • Name:sajeel
  • Car :honda accord
  • Locationlondon
Posted 02 May 2016 - 08:07 PM
Hi quick update clutch pedal fitted and working the diesel has two switches so removed one and all is working good on petrol car.
Edited by honda_saj, 02 May 2016 - 08:08 PM.
  • Matt and freddofrog like this
Regards,
saj
#5 Ryan_ictdi
Ryan_ictdi
  • Members
  • PipPip
  • 16 posts
  • Name:Ryan dempster
  • Car :Honda accord 2.2
  • LocationNorthern ireland (belfast)
Posted 25 August 2019 - 06:04 PM
Guys can you point me in the right direction for a new clutch pedal?
#6 antdad
antdad
    Advanced Member
  • Members
  • PipPipPip
  • 167 posts
  • Name:Tony
  • Car :Tourer i-cdti 07
  • LocationHeathrow
Posted 28 August 2019 - 06:53 AM
They might respond but it's a three year old thread, just contact a dealership.
#7 Channel Hopper
Channel Hopper
    Advanced Member
  • Members
  • PipPipPip
  • 968 posts
  • Name:Stephen
  • Car :Accord 7 Estate 2005
  • LocationKT8 Postcode
Posted 30 August 2019 - 11:52 AM
Just out of interest does anyone know if this is a one off failure of the pedal ?
Since the brake (and accelerator) are of the same design, if either broke when needed most this would constitute a key cause within any accident investigation.
A listed recall notification might get you one from Honda gratis.
#8 Mr Honda
Mr Honda
    Advanced Member
  • Members
  • PipPipPip
  • 1,299 posts
  • Name:Honda
  • Car :Accord
  • LocationEire
Posted 30 August 2019 - 01:08 PM
The car had a 3 year guarantee, it's up to you to maintain it for as long has you want to own it. Brake pedals have been known to be broken in major accidents just from sheer force of occupant pressures at point of impact. Determining if it broke before an accident would see a weakening or fatigue of the metals and therefore putting the blame on the owner for poor maintenance and not the manufacturer for shoddy build.
#9 Channel Hopper
Channel Hopper
    Advanced Member
  • Members
  • PipPipPip
  • 968 posts
  • Name:Stephen
Posted 31 August 2019 - 10:13 AM
This is why I am asking about the reason for the fracture, even though Ryan is enquiring about a clutch pedal, which (I assume) is the least likely to break in an accident.
Have cabin pedals ever been part of an Accord/Honda vehicle recall, or mentioned in historic statistical analysis either from VOSA or another country overseer ?
Some other parts that are deemed to be potentially life threatening (eg. the exhaust manifold) do appear to get an extension to the three year rule and surprisingly, this fault is not mentioned in the government recall links, regardless of the model entered, though I have put just one year into the search.
https://www.check-ve...ar/2005/recalls
#10 Channel Hopper
Channel Hopper
    Advanced Member
  • Members
  • PipPipPip
  • 968 posts
  • Name:Stephen
Posted 31 August 2019 - 10:28 AM
I appear to have an outstanding recall on my vehicle, not a Honda part.
There is an outstanding recall/update on your vehicle:
  • Safety recall: front pass airbag over pressurised
Edited by Channel Hopper, 31 August 2019 - 10:29 AM.
