scotsgent
I am gradually getting to know my new motor: 2010 Accord Tourer ES GT 2.2.
1) The windscreen washer pressure is pretty weak and in fact the rear one does not work at all.
I suspect a blocked filter. I believe there is a filter built into the fixing plug where the pump fits into the washer?.
So..........what's the best/easiest way to access the pump? - by removing the front bumper OR getting access through the drivers side wheel arch? Also, on the 8th generation is there one pump for all washers or separate ones for the front and rear? (I have no headlight washers).
2) I needed to pull a fuse from the drivers side internal fusebox - this seems a most inconvenient location! Am I missing something? - does it swing out or something?
Thanks, Terry
Thanks, Terry
