Good afternoon,
My 2.0 tourer has developed a strange air conditioning problem that has people scratching their heads.
Basically the air conditioning works beautifully, but only for a short period of time and only when the engines revs are up above about 3500rpm.
If you turn the car on at tickover and turn it to LO, it will not work. Get driving and get the revs above 3500rpm roughly, beautiful cold air will start firing out.
Cruising at 80mph, and you will noticably feel the compressor cutting in and out with a corresponding change in temperature. Gas is fully charged, relays were changed for brand new Honda items.
I am at a loss!
Any words of advice? I tried the DIY AC diagnostics, but I wasn't entirely sure what the readings should be if the system is working perfectly. Nothing seemed amiss.
I am at a loss!
