abs, vsa and (!) came on
Herdy
Nottingham
2005 CDTI Saloon
Hi folks, I was driving back from work tonight and the abs, vsa and (!) came on on the dashboard, it still drives the same and the brakes are working as they should... What could this be? Admittedly the rear brake pads are about ready for renewal. But what do you think? Or could you point me towards a thread that might help diagnose the issue.
Thanks in advance.
Ben.
Search is your friend here mate. This topic has been discussed a lot as it's very common, more so on the diesel accords apparently
Just found fahad's write up on replacing the sensor, gonna get the mechanic to run his diagnostics on it tomorrow.
