Drivers side lean
Cheddars
Lincoln
2009 Astra Twintop
Gents,
There is a horrible lean to the drivers side of the car. I've just changed both the front springs as the drivers side snapped. New springs levelled the height nicely but now there is a 10mm difference and 15 t0 20mm with drivers weight (of 16 stone :blush:). The lean was there before with the broken spring also.
One thing I did notice when changing the springs was that the drivers side was 10 times harder to compress into the shock than the passenger side. I even had to buy another pair of spring compressors and use 4 on one spring.
Any ideas guys?
Can only ***ume whatever snapped that Spring has damaged something else as well. If it was me I'd throw it in a garage and get it up on a ramp so they can have a good look.
Check your alloys and tyres I had lean before replacing tyres and swapping alloys about. Also worth getting tracking checked.
Sent from my SM-G901F using Tapatalk
