Hi
Today I found out that my bearing on the pulley for the aircon is faulty.
Everythime the aircon clutch get engaged I hear a scweaky noice commong from the pulley. I did remove my belt to se if there was any slack on the pulley, and as I expected it was.
My local dealer say I need to buy the hole clutch set. 4900 NOK for that one. I elive I only need to change the bearing itself inside the pulley. It will be around 200 NOK insted.
So, have anybody done this before, ot experienced the same issue? If not I will make a DIY on this one when I am going to do this. What does this clutch set cost in UK?
Thanks!
Marius
Thanks!
Marius
