Jump to content
misfire and black smoke
  • Please log in to reply
33 replies to this topic
#1 buckfusby
buckfusby
  • Members
  • PipPip
  • 49 posts
  • Name:Geof
  • Car :accord ex i ctdi
  • Locationglinton
Posted 25 October 2016 - 10:46 PM
H E L P  I have had a remap stage one and egr blanked (thanks Farad) but engine still misfiring (if it was petrol i would suspect faulty leads/plugs ) but it has been in garage for a week now and has had injectors refurbished  fuel flow checked return fuel flow checked  but the dammed thing is still "missing" you can smell the unburnt fuel!! I pick it up tomorrow and will be getting a written report as to what has been done will post results when i get them.....any ideas starting to spend to much money..07 plate cdti 2.2
#2 F6HAD
F6HAD
    Affiliate / Co-Founder
  • Administrators
  • 12,770 posts
  • Name:Fahad
  • Car :2015 Audi A6
  • LocationHalifax
Posted 26 October 2016 - 12:04 AM
Hi Geof,
I recall two of your injectors were badly out of balance. Have the garage checked those? And is the inlet manifold thoroughly clean?
Can you ask them to run a compression test on each cylinder? The car did have a remap on it previously which I've solved but the damage may already be done..
Posted Image
#3 buckfusby
buckfusby
  • Members
  • PipPip
  • 49 posts
  • Name:Geof
  • Locationglinton
Posted 26 October 2016 - 08:24 AM
Thanks Fahad   Yes they have done a compression test and all 4. Cylinders are an even 310   injectors refurbished but do not know if "coded to car" also need to check if fuel filter it a Honda one if not i will get it changed
#4 F6HAD
F6HAD
  • Administrators
  • 12,770 posts
  • Name:Fahad
  • Car :2015 Audi A6
  • LocationHalifax
Posted 26 October 2016 - 05:16 PM
Fuel filter won't be causing that missing Geof.. it was the middle two cylinders out of balance. 1 and 4 were spot on.. I suspect possibly very badly blocked inlet around those two injector ports.. or maybe a knackered cylinder head even.
Posted Image
#5 buckfusby
buckfusby
  • Members
  • PipPip
  • 49 posts
  • Name:Geof
  • Locationglinton
Posted 26 October 2016 - 06:14 PM
Just found out that the injectors are "leaking" i washed the engine down and got a bit to much water around the injectors which started spurting up (engine was running) so it seems that they are not seated correctly!!!  So do i take them out if so how do i check the seats!!Thanks
#6 F6HAD
F6HAD
  • Administrators
  • 12,770 posts
  • Name:Fahad
  • Car :2015 Audi A6
  • LocationHalifax
Posted 26 October 2016 - 09:46 PM
Can you tell if it's the middle two?
Remove the stretch bolts and ease the injectors out, they may be seized in so be careful not to damage the alloy block.
Clean the seat of the injector port and use new washers from Honda.
Don't damage the alloy thread..
Posted Image
#7 buckfusby
buckfusby
  • Members
  • PipPip
  • 49 posts
  • Name:Geof
  • Locationglinton
Posted 27 October 2016 - 12:36 AM
This may sound daft but how do i clean them and stop any muck going into the cylinder?  also they have all been taken out so hopefully it will not be to much trouble removing them again
#8 Goodluckmonkey
Goodluckmonkey
    Advanced Member
  • TA Friends
  • PipPipPip
  • 1,618 posts
  • Name:Matt
  • Car :CN2
  • LocationKent
Posted 27 October 2016 - 08:12 AM
I used an injector seat cutter plastered with grease to clean mine.
Of course, you don't want to cut a new seat, just clean it, so you don't need to apply loads of force.
The debris from the hole sticks to the grease.
-35mm Apex Springs
#9 Goodluckmonkey
Goodluckmonkey
    Advanced Member
  • TA Friends
  • PipPipPip
  • 1,618 posts
  • Name:Matt
  • Car :CN2
  • LocationKent
Posted 27 October 2016 - 08:27 AM
This is what I was getting out of the seats.
As Fahad says, it's important that you use new copper washers to seat the injectors, or that you anneal your old ones. (I get them cherry red with a plumbers torch, then drop them in a mug of cold water)
Same goes for his comment on the stretch bolts that hold the injectors in. Make sure the bolt threads, and the threads in the head are spotless before you install.
-35mm Apex Springs
#10 buckfusby
buckfusby
  • Members
  • PipPip
  • 49 posts
  • Name:Geof
  • Locationglinton
Posted 14 November 2016 - 02:52 PM
Well the saga goes on to top it all i had the offside ball joint separate dropped the car on its nose (when half way round a junction!!) busted the driveshaft bearings gouged out the inside of the wheel....and i still have this ****** misfire? / over fueling and getting worse...it is still ok when stone cold so do i go around with a great big chiller attached to the engine!!!!!!LOL
#11 F6HAD
F6HAD
  • Administrators
  • 12,770 posts
  • Name:Fahad
  • Car :2015 Audi A6
  • LocationHalifax
Posted 14 November 2016 - 05:00 PM
Hi mate, so the injectors have all been tested and are fine?
Posted Image
#12 buckfusby
buckfusby
  • Members
  • PipPip
  • 49 posts
  • Name:Geof
  • Locationglinton
Posted 16 November 2016 - 06:17 PM
Hi again Farad..yes injectors all injectors removed sent off for testing/refurb refitted still this "misfire" i had some codes come up yesterday both the same P1237 and again all seems great when cold!! losing what little hair i have left LOL
#13 F6HAD
F6HAD
  • Administrators
  • 12,770 posts
  • Name:Fahad
  • Car :2015 Audi A6
  • LocationHalifax
Posted 16 November 2016 - 11:42 PM
P1237 is actually a boost error Geof.. it's possible the sticking turbo is causing your misfire.
Posted Image
#14 buckfusby
buckfusby
  • Members
  • PipPip
  • 49 posts
  • Name:Geof
  • Locationglinton
Posted 17 November 2016 - 03:06 PM
So is it a big expensive job to replace / repair!!!!!!sob sob
#15 F6HAD
F6HAD
  • Administrators
  • 12,770 posts
  • Name:Fahad
  • Car :2015 Audi A6
  • LocationHalifax
Posted 17 November 2016 - 05:32 PM
Not really, it's just a turbo.. but I'm really a bit confused with this one if I'm honest. That missing is on two cylinders
Posted Image
#16 buckfusby
buckfusby
  • Members
  • PipPip
  • 49 posts
  • Name:Geof
  • Locationglinton
Posted 02 January 2017 - 07:43 PM
Bang  the turbo has gone ...smoke everywhere had to stall engine as it started to race!! and the ignition key would not shut it down (assume oil from turbo was keeping it running ) so turbo off next and inspect for further damage ...anyone know where i can pick up a reasonable priced turbo ....as long there is no engine damage!!!!!rogue car!!
Edited by buckfusby, 02 January 2017 - 07:44 PM.
#17 Goodluckmonkey
Goodluckmonkey
    Advanced Member
  • TA Friends
  • PipPipPip
  • 1,618 posts
  • Name:Matt
  • Car :CN2
  • LocationKent
Posted 02 January 2017 - 10:09 PM
All the shrapnel should go down the exhaust if it goes anywhere.
Even if you had any of the cold-side assembly go up the boost pipe, it'd do well to get past the intercooler.
The turbo cartridge from the civic's the same, but you need to use the accord housings. (My current turbo's made from civic and accord parts)
Edited by Goodluckmonkey, 02 January 2017 - 10:11 PM.
-35mm Apex Springs
#18 buckfusby
buckfusby
  • Members
  • PipPip
  • 49 posts
  • Name:Geof
  • Locationglinton
Posted 07 January 2017 - 07:16 PM
Thanks for the reply hopefully it has not damaged anything ...does anyone on here know of a mechanic who can sort this out for me and not cost me a remortgage!!!!
#19 F6HAD
F6HAD
  • Administrators
  • 12,770 posts
  • Name:Fahad
  • Car :2015 Audi A6
  • LocationHalifax
Posted 07 January 2017 - 07:36 PM
Hi, any decent mechanic can swap a turbo on this car. Quite a few members have actually done it themselves..
Posted Image
#20 Goodluckmonkey
Goodluckmonkey
    Advanced Member
  • TA Friends
  • PipPipPip
  • 1,618 posts
  • Name:Matt
  • Car :CN2
  • LocationKent
Posted 07 January 2017 - 08:42 PM
It's not that bad a job TBH.
The worst bit's slowly working all the nuts off without shearing the studs.
At least you stand half a chance though as honda use brass nuts.
-35mm Apex Springs
