Thanks for reply Sajeel going to try reset window regulator 1st before I have to buy new regulator,came across this does anyone no if i should try this
Honda has released a service manual update regarding power window problems, including up/down movement on its own, slow to open/close, squeals, creaks, clunks or clicks.
Affected vehicles include 2003-2010 Accord, 2006-2010 Civic, 2007-2010 Civic Hybrid, 2007-2010 CR-V, 2003-2010 Element, 2009-2010 Fit, 2010 Insight, 2005-2010 Odyssey, and 2009-2010 Pilot and Ridgeline.
SYMPTOM 1
When using the auto-up function, the driver or passenger front window goes up and then reverses on its own.
PROBABLE CAUSE
The power window control unit needs to be reset, or the run channel is damaged or dirty.
REPAIR PROCEDURE
NOTE: You must perform the manual reset from the power window switch at the affected window.
1. Turn the ignition switch ON.
2. Lower the window all the way down with the power window switch.
3. Open the affected door.
NOTE: Perform steps 4 through 7 within 5 seconds of each step. Perform these steps a total of four times in a row. These steps clear the control unit’s memory.
4, Turn the ignition switch to the LOCK position.
5. Push down and hold the power window switch.
6. Turn the ignition switch to the ON position.
7. Release the power window switch. Make sure that the auto-up feature doesn’t work. If it does, perform steps 4 through 7 again, paying close attention to the 5-second time limit for up to three more times for each series of steps.
8. Lower the window all the way down using the power window switch.
9. Pull up and hold the power window switch until the window goes all the way up, then keep holding the switch for 1 second. Make sure that the auto-up/down feature works correctly by lowering and raising the window with the power window switch. If it does not work correctly, repeat the manual reset several times, paying close attention to the 5-second time limit. If it still does not work, troubleshoot the power window circuit.
