As per ***le
Been reading quite a few posts but still a little confused with this
Car sat for a week ..starts fine etc.. before parking up .. finnished work got in car .. started and vsa light is on ....no abs lights. Drives fine
Cant turn on / off via button
Tried reset etc ... using brake ..then one wire in pin 9 ..
Ill go get the codes now ... maybe just needs a drive again . I dunno but now battery flat . ( left obd2 adapter in all night so that may be the culprit of the flat battery )
Codes cleared and wifes thrown away the paper i wrote them down on :/
Ok so pin 9 to ground
Brings up scs service DTC no
Followerd procedure to reset vsa using abs light ..vsa switch etc but nothing
Off to charge battery now
Any ideas ?
Any ideas ?
