Clear tubing size for bleeding brakes
ally
Scotland
Accord 2.0 ivtec
Hi all,
Anyone know the size (width) of the clear tubing required to bleed the brakes on a 7th gen CL7 2.0 Petrol?
I'm going to change the pads and discs so thought it would be worth doing at the same time. Also how much brake fluid will I need?
Im going to follow this video on you tube, looks straight forward
https://www.youtube.com/watch?v=n1NvtUwfRJc
Mine is id 6mm and od 10mm soft part of vacuum bleed kit
sent using tapatalk
Thanks Saj. Would yours be the same as mine?
Im looking to buy the 6mm od 9mm from here if it is as the dont seem to have 6mm od 10mm
http://m.ebay.co.uk/itm/PVC-Tube-Clear-Plastic-Hose-Pipe-Food-Grade-Fish-Pond-Car-Aquariums-Air-/221293533874?var=520393172363&hash=item33861f5ab2%3Am%3AmvmCix3J9tOeCuV7Mku8q0w&_trkparms=pageci%253Ae4793222-e56e-11e6-a138-74dbd1a0cf1a%257Cparentrq%253Ae5b43fa51590a5e2a5616384ffa5565a%257Ciid%253A10&varId=520178658700
Also if anyone knows how much brake fluid i should have to complete the job it would be good.
Never flushed brakes before so not sure of the stupidness of this next question.
Does it matter where i get the brake fluid from or what brand i get. Im guessing as longs as its the correct 'dot' rating it would be fine?
That will do the job, dot 4.1 you may need about 2 bottles max for a full flush.
sent using tapatalk
That tool could be better. Just need a valve and hose clip. Good shout
Can anybody confirm if this brake fluid is good enough or should i go honda dot4?
http://www.eurocarpa...70271&0&cc5_179
Sorry dot 4 is fine you can use original honda which is suggested
sent using tapatalk
Holdcroft honda will give you forum discount
sent using tapatalk
Thanks saj.
They quoted me 7£ for 500ml. Il need 2 bottles which is why i thought i could just get the pagid dot4 for ecp. About£5 from ecp.
Would that be causing problems u think?
Looks good and im sure its worth it.
Im just weighing up what should be genuine replacement and what i can get away with on the cheap without affecting the car.
Its 11 years old now so dont want to be throwing money at it for no good reason
Well mine is 2003 and a few good pounds will be worth it it's not every day you replace brake or clutch fluid.
sent using tapatalk
True.
Iv had in the past month a clutch replacement with mtf change. Oil, oil filter, pollen filter, air filter and spark plugs all genuine.
Brake discs and pads (mintex) and orginal honda coolant being done over the next fews days as well as rear drop links and a gearbox mount...
Pockets taken a hit☺
Because of that im going to go with pagid dot4 and just change it every couple of years
That's ok dot4 pagid will be fine
sent using tapatalk
