Jump to content
125k service, what do they do?
  • Please log in to reply
54 replies to this topic
#1 spud350
spud350
    Advanced Member
  • Members
  • PipPipPip
  • 125 posts
  • Name:No.6
  • Car :Tourer 2.4 Type-S
  • Locationopp north
Posted 31 January 2017 - 09:41 PM
Rang a couple of dealers to book a 125k service and the price was the best part of £100 difference. Seems they have a different list of jobs to do. Anyone got a job sheet for a 2.4 7th gen so I know which to choose.
Cheers Spud.
#2 Channel Hopper
Channel Hopper
    Advanced Member
  • Members
  • PipPipPip
  • 854 posts
  • Name:Stephen
  • Car :Accord 7 Estate 2005
  • LocationKT8 Postcode
Posted 02 February 2017 - 02:03 PM
Im in a local dealer at 4pm later today and can ask.
Is it manual or automatic ?
  • honda_saj likes this
#3 spud350
spud350
    Advanced Member
  • Members
  • PipPipPip
  • 125 posts
  • Name:No.6
  • Locationopp north
Posted 04 February 2017 - 08:48 AM
Damn, too late, it's the manual.
#4 Grayedout
Grayedout
    Advanced Member
  • Members
  • PipPipPip
  • 271 posts
  • Name:Graham Marshall
  • Car :2004 Accord 2.2
  • LocationDerbyshire
Posted 04 February 2017 - 05:47 PM
Autodata lists the following for the 125k service for a 2.4 2008 - 2015
Total time - 0.80 hrs
Select all
VEHICLE ON FLOOR
  1. Footbrake travel
    Check/report
  2. Parking brake travel
    Check/adjust
  3. Headlight levelling system
    Check
VEHICLE FULLY RAISED
  1. Engine oil leaks
    Check/report
  2. Engine oil
    Drain/refill
  3. Engine oil filter
    Renew
  4. Manual transmission oil leaks
    Check/report
  5. Manual transmission oil
    Check/top-up
  6. Automatic transmission fluid (ATF) leaks
    Check/report
  7. Steering joints
    Check/report
  8. Steering rack/box
    Check/report
  9. Steering column couplings
    Check/report
  10. Suspension joints/seals/gaiters
    Check/report
  11. Drive shaft joints/seals/gaiters
    Check/report
  12. Road springs
    Check/report
  13. Shock absorbers/mountings
    Check/report
  14. Exhaust system/mountings
    Check/report
  15. Brake pipe corrosion
    Check/report
  16. Fuel system leakage
    Check/report
VEHICLE HALF RAISED
  1. Front brake pads
    Check/report
  2. Front brake discs
    Check/report
  3. Front brake calipers/cylinders
    Check/report
  4. Rear brake pads
    Check/report
  5. Rear brake discs
    Check/report
  6. Rear brake calipers/cylinders
    Check/report
  7. Brake hydraulic system
    Check/report
  8. Brake flexible hoses
    Check/report
  9. Tyre condition
    Check/report
  10. Tyre pressures
    Check/adjust
ENGINE BAY OPERATIONS
  1. Washer bottle(s)
    Check/top-up
  2. Brake fluid reservoir
    Check/top-up
  3. Power steering fluid
    Check/top-up
  4. Engine coolant/anti-freeze
    Check/top-up
  5. Automatic transmission fluid (ATF)
    Check/top-up
  6. Auxiliary drive belt(s)
    Check/adjust
FINAL ITEMS CHECK
  1. Cabin filter (if fitted)
    Renew
  2. Headlamp alignment
    Check/adjust
  3. Tyre repair canister expiry date
    Check/report
ROAD TEST VEHICLE
  1. Vehicle handling/operation/performance
    Check/report
Parts Engine oil - Drain/refill   Engine oil filter - Renew   Manual transmission oil - Check/top-up   Screen wash - Check/top-up   Brake fluid - Check/top-up   Power steering fluid - Check/top-up   Engine coolant/antifreeze - Check/top-up   Automatic transmission fluid (ATF) - Check/top-up   Cabin filter - Renew
#5 honda_saj
honda_saj
    Advanced Member
  • Members
  • PipPipPip
  • 1,059 posts
  • Name:sajeel
  • Car :honda accord
  • Locationlondon
Posted 05 February 2017 - 12:33 PM
If you can find a dealer who will really do all that I would pay them but from past experiences most dealers are rubber stampers I don't trust anyone with my vehicle if i can't see with being done that includes dealers as 1 dealer did service and forgot rover fill with oil other dealers I used in past have failed to diagnose problems correctly in fact most times wrong diagnostic to expensive parts which who knows if they fit or not so sorry but my trust with most dealers is long lost if i must visit a dealer i require to view the vehicle while work is done even if it's from a window away from workshop as i know they allow customers on workshop
sent using tapatalk
Regards,
saj
#6 honda_saj
honda_saj
    Advanced Member
  • Members
  • PipPipPip
  • 1,059 posts
  • Name:sajeel
  • Car :honda accord
  • Locationlondon
Posted 05 February 2017 - 12:35 PM
Also a decent garage can diagnose, stamp the book and do the vehicle in front of you, I only use garages from good garage scheme or motor ombudsman scheme
sent using tapatalk
Regards,
saj
#7 spud350
spud350
    Advanced Member
  • Members
  • PipPipPip
  • 125 posts
  • Name:No.6
  • Locationopp north
Posted 13 February 2017 - 08:07 PM
Right thanks, Ill take it to the one who says they'll do most.  :)
#8 spud350
spud350
    Advanced Member
  • Members
  • PipPipPip
  • 125 posts
  • Name:No.6
  • Locationopp north
Posted 03 April 2017 - 08:31 PM
Select all
VEHICLE ON FLOOR
  1. Footbrake travel
    Check/report
    Check/adjust
    Check
  1. Engine oil leaks
    Check/report
  2. Engine oil
    Drain/refill
    Renew
    Check/report
    Check/top-up
    Check/report
  7. Steering joints
    Check/report
    Check/report
    Check/report
    Check/report
    Check/report
  12. Road springs
    Check/report
    Check/report
    Check/report
    Check/report
    Check/report
VEHICLE HALF RAISED
  1. Front brake pads
    Check/report
    Check/report
    Check/report
  4. Rear brake pads
    Check/report
  5. Rear brake discs
    Check/report
    Check/report
    Check/report
    Check/report
  9. Tyre condition
    Check/report
  10. Tyre pressures
    Check/adjust
  1. Washer bottle(s)
    Check/top-up
    Check/top-up
    Check/top-up
    Check/top-up
    Check/top-up
    Check/adjust
FINAL ITEMS CHECK
    Renew
    Check/adjust
    Check/report
ROAD TEST VEHICLE
    Check/report
Actually getting round to getting it serviced and for £350 it doesn't seem a lot for your money, especially at 0.8 hrs. Honda say they want it 4 hrs ! and I don't think ever in it's life have the valve clearances been checked.
#9 Cliffordski
Cliffordski
    And still...
  • TA Friends
  • PipPipPip
  • 1,405 posts
  • Name:Cliff
  • Car :06 Tourer 2.4 EX man
  • LocationCounty Durham
Posted 03 April 2017 - 08:50 PM
This is why a little home DIY goes a long way.
Most of those checks are done on the MOT for £50 or less.
You can change the cabin filter yourself - buy one for £10 on eBay - the handbook shows how and it takes less than 5 minutes.
That leaves the oil change, and if you can do your own, the oil and filter costs about £30.
Having said that, if Honda want it 4 hours, they'll be doing the full works - much more than what Autodata says.
#10 freddofrog
freddofrog
    won 16.4k on Euro lottery :)
  • Banned
  • PipPipPip
  • 7,326 posts
  • Name:.Freddo
  • Car :TBD
  • LocationOff abroad
Posted 04 April 2017 - 03:13 AM
The reason they want it 4 hours is because they don't know precisely what time they'll do it, a bit like get a washing-machine delivered.
  • Nathylad and honda_saj like this
#11 Jon_G
Jon_G
    No Longer Active
  • Banned
  • PipPipPip
  • 5,124 posts
  • Name:Jon
  • Car :2005 Tourer i-CTDi
Posted 04 April 2017 - 05:43 AM
...Most of those checks are done on the MOT...
+1
Which is good enough for me!
#12 Cliffordski
Cliffordski
    And still...
  • TA Friends
  • PipPipPip
  • 1,405 posts
  • Name:Cliff
Posted 04 April 2017 - 07:42 AM
Ah ok, good shout.
The op may find this a possible alternative
http://www.halfordsa...-whats-included
#13 Goodluckmonkey
Goodluckmonkey
    Advanced Member
  • TA Friends
  • PipPipPip
  • 1,616 posts
  • Name:Matt
  • Car :CN2
  • LocationKent
Posted 04 April 2017 - 10:43 AM
Change the oil, wipe the oil filter, give it back. ;)
  • Jon_G likes this
-35mm Apex Springs
#14 Jon_G
Jon_G
    No Longer Active
  • Banned
  • PipPipPip
  • 5,124 posts
  • Name:Jon
Posted 04 April 2017 - 10:51 AM
Maybe use it for a trip to Gregg's before giving it back (at high speed, if it's a performance car).
There was a great clip on Civinfo showing how Honda technicians discussed and treated a customer's CTR, not realising that he'd left his dash cam running in permanently on mode. Most worrying was the way it was hammered over a speed hump...
  • honda_saj and Goodluckmonkey like this
#15 Goodluckmonkey
Goodluckmonkey
    Advanced Member
  • TA Friends
  • PipPipPip
  • 1,616 posts
  • Name:Matt
  • Car :CN2
  • LocationKent
Posted 04 April 2017 - 10:58 AM
Yeah, you hear the horror stories.
Why I service my own, or on a very rare occasion it gets worked on by someone I trust implicitly.
-35mm Apex Springs
#16 Channel Hopper
Channel Hopper
    Advanced Member
  • Members
  • PipPipPip
  • 854 posts
  • Name:Stephen
Posted 04 April 2017 - 11:36 AM
  • Jon_G, toffee_pie and Goodluckmonkey like this
#17 Andyjdmteg
Andyjdmteg
    Advanced Member
  • Members
  • PipPipPip
  • 590 posts
  • Name:Andy Collins
  • Car :Accord Type S
  • LocationHitchin
Posted 04 April 2017 - 09:48 PM
Having worked at a local dealer I can tell you the "pdi" and road tests were more like a rallycourse. There were records set in certain models around notorious bends etc.
  • Jon_G and Goodluckmonkey like this
#18 Goodluckmonkey
Goodluckmonkey
    Advanced Member
  • TA Friends
  • PipPipPip
  • 1,616 posts
  • Name:Matt
  • Car :CN2
  • LocationKent
Posted 05 April 2017 - 07:24 AM
Haha. For a year I put the PDI mileage on motorcycles for a dealer, and can relate to this.
We exported a lot of bikes to Germany with 9 miles on the clock and worn hero blobs on the footpegs.
-35mm Apex Springs
#19 honda_saj
honda_saj
    Advanced Member
  • Members
  • PipPipPip
  • 1,059 posts
  • Name:sajeel
  • Car :honda accord
  • Locationlondon
Posted 05 April 2017 - 01:29 PM
I disagree most dealers are rubber stampers and that's me being polite I do another name for them but won't mention here
sent using tapatalk
Regards,
saj
#20 honda_saj
honda_saj
    Advanced Member
  • Members
  • PipPipPip
  • 1,059 posts
  • Name:sajeel
  • Car :honda accord
  • Locationlondon
Posted 05 April 2017 - 01:30 PM
You are correct but the joke is they will charge you charge 4 hours storage is not cheap at dealers lmao rubber stampers
sent using tapatalk
Edited by honda_saj, 05 April 2017 - 01:32 PM.
Regards,
saj
