Jump to content
Power steering fluid leaking
  • Please log in to reply
27 replies to this topic
#1 f2raf
f2raf
    Advanced Member
  • Members
  • PipPipPip
  • 480 posts
  • Name:Imran
  • Car :Honda Accord
  • LocationRochdale
Posted 11 February 2017 - 03:39 PM
Steering was not smooth and making sci-fi noises, inspected ps fluid, reservoir was below min level, topped it up, past max, after 1 day its dropped down to just under max. Suspect leak somewhere. Any idea where I start. Please
#2 Andyjdmteg
Andyjdmteg
    Advanced Member
  • Members
  • PipPipPip
  • 590 posts
  • Name:Andy Collins
  • Car :Accord Type S
  • LocationHitchin
Posted 11 February 2017 - 06:29 PM
Could be anywhere tbh start with the top hoses and work your way down to the rack. Ideally with someone moving the steering wheel back and forth and the car jacked up fullly at the front and engine running.
#3 Goodluckmonkey
Goodluckmonkey
    Advanced Member
  • TA Friends
  • PipPipPip
  • 1,618 posts
  • Name:Matt
  • Car :CN2
  • LocationKent
Posted 11 February 2017 - 08:28 PM
Prime suspects will the the top hose up near the rocker box, or the metal cooling loop that runs across the front of the car.
Don't discount the rubber pipes going slack at the reservoir either. I had to trim 1/2" of each of mine for a nice snug fit again as it was weeping.
-35mm Apex Springs
#4 f2raf
f2raf
    Advanced Member
  • Members
  • PipPipPip
  • 480 posts
  • Name:Imran
  • Car :Honda Accord
  • LocationRochdale
Posted 12 February 2017 - 10:12 AM
Thank you will take a look today.
#5 f2raf
f2raf
    Advanced Member
  • Members
  • PipPipPip
  • 480 posts
  • Name:Imran
  • Car :Honda Accord
  • LocationRochdale
Posted 18 February 2017 - 05:22 PM
The level hasn't dropped yet, it must be a slow flow
#6 f2raf
f2raf
    Advanced Member
  • Members
  • PipPipPip
  • 480 posts
  • Name:Imran
  • Car :Honda Accord
  • LocationRochdale
Posted 04 July 2017 - 02:14 AM
After 6 months of now topping up the PS fluid, its been in the garage for a diagnosis twice now but can't locate the leak. The steering rack and underneath is all covered in oil which doesn't help. So I've had they bottom end and engine bay jet washed tiday, its back in on Wednesday so hopefully they will be able to locate the leak.
#7 Jon_G
Jon_G
    No Longer Active
  • Banned
  • PipPipPip
  • 5,124 posts
  • Name:Jon
  • Car :2005 Tourer i-CTDi
Posted 04 July 2017 - 06:37 AM
Just last week my PAS oil cooler developed a significant leak, which emptied the reservoir. Because the journey was up the M5 at speed, the oil was blown backwards to cover the engine undershield and ran along the driver's lower wishbone to even coat the wheel!
Pretty easy to check the cooler for leakage by shining a torch through the grill under the numberplate.
The replacement 'cooler'(nothing special, just a shaped 10mm OD steel pipe, no brackets, no fins) is stupidly expensive from Honda (Lings comes in at pretty much £200 with the VAT!!!). One option I considered was to make a whole new cooler using soft copper pipe (£22 for a 10m reel at Screwfix), but in the end I sawed out the ~40mm corroded lower portion and replaced it with some braided fuel pipe.
  • f2raf likes this
#8 f2raf
f2raf
    Advanced Member
  • Members
  • PipPipPip
  • 480 posts
  • Name:Imran
  • Car :Honda Accord
  • LocationRochdale
Posted 04 July 2017 - 10:34 AM
thank you, ill pass the comments on to the garage tomorrow.
#9 f2raf
f2raf
    Advanced Member
  • Members
  • PipPipPip
  • 480 posts
  • Name:Imran
  • Car :Honda Accord
  • LocationRochdale
Posted 05 July 2017 - 09:46 PM
so back at the garage today and tossed back to the jetwahs place as they hadn't actually removed the oil from the steering rack.  Th emechanic pointed the area out to me, it is towards the rear of the engine at the bottom end, there is something like a black rubber ribbed sleeve on a pipe which is covered in oil and he suspects it maybe a seal gone in here, also the area above it was covered in oil, its all been removed now, but it sat the back of the engine, not the front so cant be seen via the grill.  Its back in tomorrow, so we will see again! he thinks the bottom end may have to come off  :o
#10 freddofrog
freddofrog
    won 16.4k on Euro lottery :)
  • Banned
  • PipPipPip
  • 7,326 posts
  • Name:.Freddo
  • Car :TBD
  • LocationOff abroad
Posted 06 July 2017 - 12:47 PM
I'm assuming that he thinks the leak is coming from the return pipe from the steering rack to the cooler pipe.
In that case he means the sub-frame may have to be removed, which is a big job, the exhaust has to come off etc etc.
However he shouldn't have to remove it, just loosen it to lower it enough to get to the pipe.
#11 f2raf
f2raf
    Advanced Member
  • Members
  • PipPipPip
  • 480 posts
  • Name:Imran
  • Car :Honda Accord
  • LocationRochdale
Posted 07 July 2017 - 10:53 AM
It has been in teh garage on the ramp running for 3 hours yesterday, with the steering also being turned, but no sign of any leaks, also been cleaned again using solvents to use all excess oil/dirt/grime underneath, so he can see any new oil seeping from anywhere and he cant see anything.  He says now bring it back in a couple of weeks to see if we can see any oil from anywhere.  Just cant trace it!  its inconsistent too, sometimes i top of a tint bit per week and other times a lot more.    I'll have to try and locate it by keeping an eye on it. in the meatime the Honda PS fluid stuff is running through it, on second bottle now, is there a cheaper alternative i can use wilst its flushing through, at least its had a complete new flush.
#12 Goodluckmonkey
Goodluckmonkey
    Advanced Member
  • TA Friends
  • PipPipPip
  • 1,618 posts
  • Name:Matt
  • Car :CN2
  • LocationKent
Posted 07 July 2017 - 10:58 AM
Is the high pressure hose still clean?
Mine went up near the cam cover, bit ran down the back of the block and all over the rack. All the oil was nowhere near the hole.
-35mm Apex Springs
#13 f2raf
f2raf
    Advanced Member
  • Members
  • PipPipPip
  • 480 posts
  • Name:Imran
  • Car :Honda Accord
  • LocationRochdale
Posted 07 July 2017 - 11:21 AM
tbh, i wouldn't know which hose you are referring to, everything underneath has been jetwashed 3 times, after solvents and all is dry & clean, sorry i know it doesnt help,
#14 Goodluckmonkey
Goodluckmonkey
    Advanced Member
  • TA Friends
  • PipPipPip
  • 1,618 posts
  • Name:Matt
  • Car :CN2
  • LocationKent
Posted 07 July 2017 - 11:29 AM
The big one that runs from the PAS pump over and down the back of the engine.
The usually develop a little pinhole where they sit in the clip near the rocker cover, and pee PAS fluid down the back of the engine, which then gets blown back over the rack.
Edited by Goodluckmonkey, 07 July 2017 - 11:30 AM.
-35mm Apex Springs
#15 StuH
StuH
    Advanced Member
  • Members
  • PipPipPip
  • 374 posts
  • Name:Stuart
  • Car :2.4 EX Tourer
  • LocationLancashire
Posted 07 July 2017 - 11:31 AM
Are you checking from the top as well as bottom? removing any engine covers?
#16 f2raf
f2raf
    Advanced Member
  • Members
  • PipPipPip
  • 480 posts
  • Name:Imran
  • Car :Honda Accord
  • LocationRochdale
Posted 07 July 2017 - 11:33 AM
yes, the garage is doing a thorough job, the entire engine bay was cleaned top & bottom, its the cleanest its ever been
Edited by f2raf, 07 July 2017 - 11:33 AM.
#17 Jon_G
Jon_G
    No Longer Active
  • Banned
  • PipPipPip
  • 5,124 posts
  • Name:Jon
Posted 07 July 2017 - 11:36 AM
Have you had a look at the cooler? Pretty easy to shine a torch through the grill opening behind/below the front number plate... It's a simple bent 10mm steel pipe and any leakage should be obvious.
  • Goodluckmonkey likes this
#18 f2raf
f2raf
    Advanced Member
  • Members
  • PipPipPip
  • 480 posts
  • Name:Imran
  • Car :Honda Accord
  • LocationRochdale
Posted 07 July 2017 - 11:48 AM
i will take a look, thank you Jon
#19 Goodluckmonkey
Goodluckmonkey
    Advanced Member
  • TA Friends
  • PipPipPip
  • 1,618 posts
  • Name:Matt
  • Car :CN2
  • LocationKent
If it's going from the cooler pipe as Jon says, the front subframe crossmember between the radiator and the motor gets soaked.
I also had to trim the ends off the lines to the reservoir a while back too, they get slack and then it weeps fluid down the lines onto the inner wing and subframe.
  • Jon_G and f2raf like this
-35mm Apex Springs
#20 f2raf
f2raf
    Advanced Member
  • Members
  • PipPipPip
  • 480 posts
  • Name:Imran
  • Car :Honda Accord
  • LocationRochdale
Posted 07 July 2017 - 11:52 AM
thank you , i will re-examine
