Brake problems
Um4ir
London
Honda Accord i-CDTI
Hi all,
I have been hearing some noises from my brakes for a while now. It only comes on cold starts.
when applying the brakes when I first start off I can hear a clunking sound coming from beneath the car (feels like its coming from under my drivers seat !). This occurs for the first 1-2minutes
Also a screech can be heard when applying the brakes. This goes on every time I apply the brakes for about 4-5minutes.
The brakes are working fine, any ideas ?
The brakes pads are old but at last check there was still life in them.
Brakes need a strip down, clean and regreased. Sounds like the pad is sticking in the calliper
Could also be dust covers
sent using tapatalk
All looks ok. Loads of meat on that pad, but if the sliders are sticking you can get uneven pad wear, so the condition of the outer pad may not match the inner one.
