Jump to content
H22 conversions
  • Please log in to reply
35 replies to this topic
#1 Jamjar15
Jamjar15
  • Members
  • PipPip
  • 29 posts
  • Name:Kinwai
  • Car :Accords 1.8 and 2.0
  • LocationSwansea
Posted 25 February 2017 - 08:01 PM
New here and to accords but just bought 2, an 1.8 vtec sport and 2.0 se, are either of them more suited to h22 conversions? No very little about accords and preludes and only real deal with k, d and b series engines.
Are there any guides on here?
Not even sure if there are any differences between hatchbacks and saloons in terms of suspension/exhaust mounting points, looms, brakes so any advice or info would be much appreciated
#2 Jamjar15
Jamjar15
  • Members
  • PipPip
  • 29 posts
  • Name:Kinwai
  • LocationSwansea
Posted 25 February 2017 - 08:06 PM
Both are hatch aswell, also would the h23 with the h22 internals be the easier option as I believe they're the same blocks
#3 exec
exec
    Advanced Member
  • Members
  • PipPipPip
  • 1,701 posts
  • Name:Exec
  • Car :'99 2.0 SE Exec
  • LocationLondon
Posted 02 March 2017 - 01:12 PM
Are you doing this yourself? If so crack on, otherwise its waste of time, better off just buying an Accord Type R. I can't comment whether the looms etc will work with the H22, but you can drop the H22 on either car with additional work required in other areas. There are differences in specs and cars, 1.8 has smaller brake discs I believe, the sport has stiffer shocks etc. Either way if your dropping a H22 in, you will also need to mod the brakes, suspensions etc to go with the swap.
In VTEC, we trust.
#4 Shuthan
Shuthan
    Advanced Member
  • Members
  • PipPipPip
  • 177 posts
  • Name:Shuthan
  • Car :2000 Accord Type-R
  • LocationNorth London
Posted 03 March 2017 - 10:25 AM
Bit pointless dropping in a H22 into a normal Accord unless you are trying to avoid insurance costs?
As above, you need to upgrade the suspension, brakes and H22 will require additional work to fit it in, I would buy an Accord Type-R.
#5 luvmyaccord
luvmyaccord
    6th & Type R Mod
  • TA Friends
  • PipPipPip
  • 5,813 posts
  • Name:Simon.
  • Car :Accord Type R
  • LocationSuffolk
Posted 03 March 2017 - 03:45 PM
I spent long time looking into this conversion when I had my old 6th gen F20B6. If I'm honest, it's not worth it.
There's so much difference between the two that it's just not worth it. Sorry to pi55 on your cornflakes, but put simply, I wouldn't bother, just buy a type r, that's what I did.
There is a member on here that did the conversion and if I remember correctly, he said the same thing.
2001 Milano Red, Eibach springs, VtecDirect Mani, downpipe, decat and zorst, ported and polished head, K+N panel filter, VtecDirect oil cooler, lightweight pullies, XTD lightweight flywheel, Full new set of valves retainers and springs, DS250 pads, Bremtech disks, throttle body coolant bypass, New standard ATR cams and a re-built head, balance belt removed, Volk TE37 - resprayed in Anthracite. Light Tints, K+N Long Ram Typhoon.
1997 Impreza 555 RA - New Cosworth forged pistons and matching piston rings *.50 oversize.**Rebore block to suit New Crankshaft. New race quality crank bearing set. APi uprated oil pump.STi 2003 year model con rods.STi gasket and seal set, baffeled sump.* Stage 2 organic clutch, lightweight competition spec. Flywheel and balance, TD05G20 Turbo, Standalone ECU, 650cc injectors. HDi Hybrid racing front mount intercooler.
#6 Jamjar15
Jamjar15
  • Members
  • PipPip
  • 29 posts
  • Name:Kinwai
  • LocationSwansea
Posted 08 March 2017 - 04:55 PM
Reason was purely boot access, never seen a type r hatch buy after looking into the f20b6 looking like forced induction is the easier route, doing all the work myself, converted a d13 eg into a dc2 when I was 15 including making up my own loom so won't be phased by anything just want avoid making any custom parts or cutting away the chassis, built a b16 turbo a few years back and took about 2 hours from start to finish and heard these these have made 468whp on standard internals without issue
#7 sjorrit
sjorrit
    Newbie
  • Pre-Members
  • Pip
  • 1 posts
  • Name:jorrit
  • Car :Accord 2.3
  • Locationnetherlands
Posted 18 May 2017 - 04:17 PM
I also have this question, I live in the Netherlands and over here we don't have much facelifted 6th gen's. A couple years ago I found one with a 2.3 engine and manual transmission. I always wanted an ATR but we never did get the facelifted ATR. Now I can get a pretty cheap ATR from the UK but I have this crazy idea to transfer everything over to my car, benefits would be steering wheel on the correct side ;) climate control, Bose audio system with subwoofer and cruise control(hoping this is swappable). I would like to swap the engine and interior over so I have the performance of an ATR but with the luxery of a 2.3 (type-V called sometimes). Would this be possible or is it better/easier to find a JDM H23 engine and put that in my car?
Edited by sjorrit, 18 May 2017 - 04:22 PM.
  • honda_saj likes this
#8 Jamjar15
Jamjar15
  • Members
  • PipPip
  • 29 posts
  • Name:Kinwai
  • LocationSwansea
Posted 18 May 2017 - 07:21 PM
The h23 is only about 5hp more than the f20, wouldn't be worth the effort imo
#9 Goodluckmonkey
Goodluckmonkey
    Advanced Member
  • TA Friends
  • PipPipPip
  • 1,616 posts
  • Name:Matt
  • Car :CN2
  • LocationKent
Posted 18 May 2017 - 07:25 PM
Just nail a supercharger to the 2.0
-35mm Apex Springs
#10 ukcl9
ukcl9
    Advanced Member
  • Members
  • PipPipPip
  • 876 posts
  • Name:.
  • Car :CL7 Euro R
  • Locationuk
Posted 18 May 2017 - 07:40 PM
Buy a different car
k20/k24 reflasher.Test ECU available.Click on the reflash thread
http://typeaccord.co...remap-test-ecu/
#11 Shuthan
Shuthan
    Advanced Member
  • Members
  • PipPipPip
  • 177 posts
  • Name:Shuthan
Posted 18 May 2017 - 08:18 PM
You can transfer bits over but you will miss out on actually owning an ATR, it has a completely different chassis to the normal Accords.
Putting in any H series into a normal Accord is pointless in my eyes, when you have an Accord-R done for you with a H22A7 available, I would just buy an ATR and enjoy it.
#12 Jamjar15
Jamjar15
  • Members
  • PipPip
  • 29 posts
  • Name:Kinwai
  • LocationSwansea
Posted 18 May 2017 - 08:46 PM
It's all about the hatch ;) chassis a bit more floppy but you can fit your fishing rods in with ease which makes up for it lol, did the atrs get the same treatment as the dc2 and ek9 with seem welded chassis and weight options
#13 Goodluckmonkey
Goodluckmonkey
    Advanced Member
  • TA Friends
  • PipPipPip
  • 1,616 posts
  • Name:Matt
  • Car :CN2
  • LocationKent
Posted 18 May 2017 - 09:41 PM
If i wanted 200+hp and to haul fishing rods, I'd buy a 2.4 gen 7 wagon and stick a type R head and gearbox in it.
Got to be an easier way than trying to make the love child of two different 6th gens.
-35mm Apex Springs
#14 Jon_G
Jon_G
    No Longer Active
  • Banned
  • PipPipPip
  • 5,124 posts
  • Name:Jon
  • Car :2005 Tourer i-CTDi
Posted 18 May 2017 - 09:54 PM
Maybe you should consider transplanting an economical and low-carbon diesel engine into your chosen vehicle?
I recommend the Honda 2.2 i-CTDi.
  • freddofrog likes this
#15 Jamjar15
Jamjar15
  • Members
  • PipPip
  • 29 posts
  • Name:Kinwai
  • LocationSwansea
Posted 18 May 2017 - 10:11 PM
I prefer cars that started production before around 98, with the exception of the 350z just because it's so fun to drive, too many wires and sensors in modern cars.
Back to the h22 ch7 though, the standard single pot 288mm brakes are have ample stopping power with decent disks and pads, and suspension and bushes are a must even on standard cars I think, wirings fairly straight forward in hondas, so as long as the engine mounts are the same can't see it being any more difficult than doing b series conversions into d series chassis etc.
Will be a bit of trial and error with shafts and hubs when using prelude vti donor but found honda dont tend to change there parts much so hopefully just slips together lovely
As soon as I can find a decent donor I'll put my money where my mouth is and you can laugh when fail miserably and cry a little bit
Edited by Jamjar15, 18 May 2017 - 10:16 PM.
  • freddofrog and Goodluckmonkey like this
#16 Jamjar15
Jamjar15
  • Members
  • PipPip
  • 29 posts
  • Name:Kinwai
  • LocationSwansea
Posted 18 May 2017 - 10:15 PM
Ps sorry for the essay and I hate diesels so not even considering that lol
  • toffee_pie likes this
#17 freddofrog
freddofrog
    won 16.4k on Euro lottery :)
  • Banned
  • PipPipPip
  • 7,326 posts
  • Name:.Freddo
  • Car :TBD
  • LocationOff abroad
Posted 18 May 2017 - 10:23 PM
I think (and hope) that Jon was joking in #14 , but depending on if it would fit, it's not a totally mad idea ;)
  • Jon_G likes this
#18 Jon_G
Jon_G
    No Longer Active
  • Banned
  • PipPipPip
  • 5,124 posts
  • Name:Jon
Posted 18 May 2017 - 10:26 PM
I'll admit it was tongue-in-cheek, but nevertheless as sensible as any other transplant option this thread come up with!
If you're going to actually go to the trouble of fitting an 'alien' engine, then please do something really interesting like fitting a V8 (may also need conversion to RWD).
#19 93 accord
93 accord
    The 4th gen'er
  • TA Friends
  • PipPipPip
  • 2,096 posts
  • Name:Marcus
  • Car :1993 Accord CB3
  • LocationMidlands
Posted 19 May 2017 - 12:31 AM
One thing you need to be sure about is, are you going to enjoy the process of installing the H22, or are you really after the end result? Swapping is alot of effort, and its only made easy if either you happy to blow money to pay for labour or enjoy doing it your self.
Lucky for me theres big support for H22 swaps into 4th gen accords. And for the record, the ATR isnt all that. In fact my swapped 4th gen is noticably quicker than a stock ATR.
Interestingly there are a lot of Honda and non Honda options if you are after a fast hatch.
36mpg -- 200bhp  -- 8000rpm  -- 4 doors -- Honda = Perfect mix.
My Main 4th gen Page JDM H22A swap finally done!
#20 Jamjar15
Jamjar15
  • Members
  • PipPip
  • 29 posts
  • Name:Kinwai
  • LocationSwansea
Posted 19 May 2017 - 04:42 AM
Would take all the fun and glory out of it if I just gave someone money to do it lol. And wouldn't really consider it an alien engine as the h-series is an factory option in this chassis, anyone know the name of the guy that actually did this? Can't understand what part should be difficult
