I had to get mine done a little while back. Didn't do it myself but it's very easy to get to on these as it's near the top of the block on the left hand side.
Generally, disconnect the battery and give everything a few minutes to fully discharge. Undo the electrical connections to the starter and then remove the unit itself being careful not to drop anything into the opening.
Put it all back together carefully and off you go.
