gaz238
after regreasing the clutch master cylinder for years now to stop the annoying clicking noise, ive hit lucky and got a brand new old stock master cylinder from balmer lawn honda for £30. i plan on replacing it myself which looks reasonably easy as its in a accessible location however the slave cylinder looks a bit of a pig for the bleeding process. just looking for advice from anyone as to how to access the slave and the best bleeding process. ive seen elswhere that it recommends to block the slave piston somehow to make the bleeding easier and more efficient. mityvac or pedal? any thoughts? regards, gary
