Orange triangle on dash
ramondo66
scotland
honda accord
Hi all..I have a honda accord tourer 2009..I recently had an oil and filter change.when got the car back the orange triangle appeared on my dash..checked the others handbook and it tells me nothing about orange triangle with exclamation mark inside..any ideas folks
You sure the VSA button was not accidentally disengaged?
If i turn off the VSA on my accord the triangle will illuminate.
Not sure if its the same with the 8th gen
Hi ALL..PUT IN ON THE DIAGNOSTICS MACHINE AND NO FAULT FOUND...VSA BUTTON IS NOW NOT WORKING AND NO VSA WARNING LIGHT IS ON THE DASH.
What diagnostics machine are you using?
Only abs dedicated machines can read honda ABS codes.
Sent from my SM-G920F using Tapatalk
You will most likely to calibrate vsa is car petrol or diesel?
If there's no light on the dash then problem solved.
The orange triangle with exclamation mark is on the dash but when i press the VSA button it use to show up on the dash but not now,, i tried holding the VSA button in for a while but still nothing.. looks like i need to try another garage to see if their diagnostic machine can find any faults.
Switch on all indicators on including "VSA" START ENGINE all indicators go out? Now hold the vsa button in and the triangle! should appear indicating that VSA IS OFF. hold button again and VSA! will go away. If not then something is amiss.
Honda hds health check scan all dtc will bring up any problems
