Bolts to Rear anti roll bar bushes
Cheddars
Lincoln
2009 Astra Twintop
Hi guys,
Tried searching but can't find a definite answer and I honestly can't tell visually. The bolts to the bracket for the rear anti roll bar, is there a nut where it goes through the chassis or is it a threaded type hole?
I can't tell due to the amount of muck. I've managed to round the bolt without putting any effort in and wanted to confirm before getting the grinder out.
Car is a 99 6th gen
Cheers guys :)
Damn, that's a shame. I did use a 6 sided socket, but the edges of the bolt just perished :(
I think I'd leave well alone. If you need it out a garage could heat it and then try an Irwin bolt grip or similar on it. But in the meantime if it ain't broke I wouldn't try and fix it.
The Irwin bolt grips set is great,it's never failed me once when I've used it on other cars before.Well worth investment.
Not heard of them, looks useful to have ;)
