Jump to content
2.4 squeaky brake pedal
  • Please log in to reply
18 replies to this topic
#1 raffy
raffy
  • Members
  • PipPip
  • 65 posts
  • Name:David Tweddell
  • Car :2006 2.4l Exec Auto
  • LocationGlasgow
Posted 20 April 2017 - 10:27 AM
Hi folks,
I've got a 2006 facelift 2.4 exec auto saloon...recently I've noticed an annoying squeak when applying the brakes...sprayed the pedal pivot with WD40 and spray grease but still there...anyone had a similar problem and any suggestions fix ? many thanks in advance
#2 Goodluckmonkey
Goodluckmonkey
    Advanced Member
  • TA Friends
  • PipPipPip
  • 1,618 posts
  • Name:Matt
  • Car :CN2
  • LocationKent
Posted 20 April 2017 - 10:36 AM
The wife's new (to us) 54k mile FRV has an occasional squeak from the clutch pedal.
Was going to fix it, and she told me not to because it reminds her of her beloved civic, which also did it occasionally.
I'll never understand women.
-35mm Apex Springs
#3 Goodluckmonkey
Goodluckmonkey
    Advanced Member
  • TA Friends
  • PipPipPip
  • 1,618 posts
  • Name:Matt
  • Car :CN2
  • LocationKent
Posted 20 April 2017 - 10:39 AM
To answer the question though;
Really need to pull the pivot and grease it if you can.
Molybdenum grease would be my choice if you have some.
Squirting it with WD or spray grease just doesn't get to where it needs to be.
Edited by Goodluckmonkey, 20 April 2017 - 11:00 AM.
-35mm Apex Springs
#4 raffy
raffy
  • Members
  • PipPip
  • 65 posts
  • LocationGlasgow
Posted 20 April 2017 - 10:47 AM
Cheers guys, I'll have a poke about or just turn the stereo up
#5 honda_saj
honda_saj
    Advanced Member
  • Members
  • PipPipPip
  • 1,072 posts
  • Name:sajeel
  • Car :honda accord
  • Locationlondon
Posted 20 April 2017 - 11:40 PM
Can also be the master cylinder but before that apply grease and heat gun see if that resolves
Regards,
saj
#6 raffy
raffy
  • Members
  • PipPip
  • 65 posts
  • LocationGlasgow
Posted 21 April 2017 - 09:40 AM
Cheers mate...I see the pedal mechanism under the dash and where it pushes against the rubber boot bellows that goes through the bulkhead (please excuse my ignorance of what this is...master cylinder ?)..where should I apply the grease and gentle heat to let it flow ? thanks again
#7 Jon_G
Jon_G
    No Longer Active
  • Banned
  • PipPipPip
  • 5,124 posts
  • Name:Jon
  • Car :2005 Tourer i-CTDi
Posted 21 April 2017 - 09:44 AM
If you do grease the master cylinder linkage, do use an appropriate grease! Conventional greases will damage the rubber parts by making them swell and split, use a silicon or ceramic type.
But I think that MC issues cause a click rather than a squeak?
  • Cliffordski likes this
#8 raffy
raffy
  • Members
  • PipPip
  • 65 posts
  • LocationGlasgow
Posted 21 April 2017 - 10:12 AM
Thank you..I do have silicon grease but unsure where exactly I should put it..ahem
#9 Jon_G
Jon_G
    No Longer Active
  • Banned
  • PipPipPip
  • 5,124 posts
  • Name:Jon
Posted 21 April 2017 - 10:19 AM
Never done it, but people squirt it down the rod that links the clutch pedal to the cylinder and actually into the cylinder as far as you can. Best to use a syringe, as I've no idea how else you could get it all the way in.
#10 Cliffordski
Cliffordski
    And still...
  • TA Friends
  • PipPipPip
  • 1,411 posts
  • Name:Cliff
  • Car :06 Tourer 2.4 EX man
  • LocationCounty Durham
Posted 21 April 2017 - 11:21 AM
No clutch on an auto.
  • Jon_G likes this
#11 Cliffordski
Cliffordski
    And still...
  • TA Friends
  • PipPipPip
  • 1,411 posts
  • Name:Cliff
Posted 21 April 2017 - 11:26 AM
I think a brake squeak is most likely to be coming from discs/pads - is it definitely coming from the pedal ?
#12 raffy
raffy
  • Members
  • PipPip
  • 65 posts
  • LocationGlasgow
Posted 21 April 2017 - 11:56 AM
definitely coming from the pedal box area...funnily enough I was just out with the car earlier and it didn't squeak...parked up, nipped into the shops..then when I drove away it came back..odd...its not a noisy squeak just an annoying one when you become aware of it...brakes all working fine
#13 Jon_G
Jon_G
    No Longer Active
  • Banned
  • PipPipPip
  • 5,124 posts
  • Name:Jon
Posted 21 April 2017 - 12:10 PM
Oh dear!
Maybe that fix also works for the brake MC? Dunno...
#14 freddofrog
freddofrog
    won 16.4k on Euro lottery :)
  • Banned
  • PipPipPip
  • 7,326 posts
  • Name:.Freddo
  • Car :TBD
  • LocationOff abroad
Posted 21 April 2017 - 12:52 PM
Oh dear!
when I read your post, that's what I assumed you meant LOL
#15 Cliffordski
Cliffordski
    And still...
  • TA Friends
  • PipPipPip
  • 1,411 posts
  • Name:Cliff
Posted 21 April 2017 - 04:47 PM
Yeah I was just fishing - I'll try a different bait next time  :lol:
Edited by Cliffordski, 21 April 2017 - 04:47 PM.
  • freddofrog likes this
#16 honda_saj
honda_saj
    Advanced Member
  • Members
  • PipPipPip
  • 1,072 posts
  • Name:sajeel
  • Car :honda accord
  • Locationlondon
Posted 23 April 2017 - 08:16 AM
Yes you are correct mostly a click but can creak as well you need to ensure grease is o ring safe if applying to master cylinder linkage
Regards,
saj
#17 honda_saj
honda_saj
    Advanced Member
  • Members
  • PipPipPip
  • 1,072 posts
  • Name:sajeel
  • Car :honda accord
  • Locationlondon
Posted 23 April 2017 - 08:17 AM
You are correct indeed sir
Regards,
saj
#18 strockus
strockus
  • Members
  • PipPip
  • 38 posts
  • Name:Ailandas
  • Car :2.4l Executive
  • LocationCoventry
Posted 17 July 2017 - 12:05 PM
I have a similar issue as well. But mine doesn't happen all the time. It's only after I drive my Accord for a while on B roads or similar that it starts to squeak. It sounds like my break pedal as well however I have a problem with my car where my driver side inner driveshaft rubber is squeaking when turning. I just need to apply some lithium (I think?) grease from what I was told and it should fix it as there are no tears or sips on the rubber. No idea if that has to do anything with it?
#19 Jon_G
Jon_G
    No Longer Active
  • Banned
  • PipPipPip
  • 5,124 posts
  • Name:Jon
Posted 17 July 2017 - 12:09 PM
Don't put general purpose lithium grease anywhere near rubber parts... it makes them swell and split.
