2.0 Aux Belt
ch@ppers
Wilts
2.0i Tourer
have any of you guys got a how to for an aux belt change on a 2004 2.0 petrol please, any special tools needed or tips, i can only find info on the diesel
many thanks
it's very easy, you only have to rotate the tensioner to slacken the belt
14mm ring spanner on the tensioner
pull the belt off the tensioner, then pull it off the other pulleys
remember the routing !! it's fiddly to put the new one on, but IIRC it can be done all from above
Have you already done/had done the revised auxiliary belt route change?
The revised one is shorter so as to take pressure off of a pulley or two.
As in that guide for the diesel, you pull the spanner/socket on the tensioner towards you to relieve the tension on the belt
