rear wheel hub ?
bedlam
Glasgow
8th gen tourer 2.2
Hi All
Has anyone got a link to where I can buy the rear hub/wheel bearing for my 58 tourer iDETC 2.2
thanks in advance
Chris
secondhand ?? does anyone put a secondhand bearing on their car ?.
aftermarket would do
thanks
Chris
Best thing is to get the Honda part number for your car.
Start here --> http://www.lingshondaparts.com/cars/oem-car-parts-diagrams.html
When you reach the relevant page that has a drawing with part numbers listed underneath, you'll see that the part numbers begin with PFKL. To get proper Honda part numbers, remove "_pfk" from the url ;)
Then try the part number in google (or ebay)
thanks
Chris
You initially mentioned 'rear hub/wheel bearing'.
Probably nobody would fit a secondhand bearing, but an entire secondhand hub would be a good option to avoid having to use a press.
^ no press required for saloon or tourer, just like the saloon, the tourer bearing is sealed , it just "clamps" on with a high torque on the large nut.
The OE bearings on hondas are usually NTN ones.
The more expensive replacement hub that Euro car parts did was identical to.the ones I removed from my 7th Gen, NTN bearings included.
