Jump to content
idtec Accelerator Pedal Adjusted
  • Please log in to reply
1 reply to this topic
#1 TourerFan
TourerFan
  • Members
  • PipPip
  • 65 posts
  • Name:Pete
  • Car :idtec tourer manual
  • LocationWakefield
Posted 24 May 2017 - 07:41 PM
Hi All,
I have found, particularly on long journeys, that the accelerator pedal is not comfortable to use. At motorway speeds it would make my ankle ache and if I increased the pressure on the pedal I would be going too fast (speeding points) and if I relaxed the pressure the speed would drop to about 65 mph. So I decided to have a look at the pedal/pedal box set up.
To cut to the chase, I found that inserting 3 x 1" M8 washers under the lower mounting pedal box stud has improved the feel of the accelerator and removed any play in the linkage between the pedal and the pedal box.
This modification lifts the angle of the pedal box arm and has the added benifit of making the car feel more responsive to the accelerator.
Cheers,  Pete.
  • Matt, freddofrog and Jon_G like this
#2 honda_saj
honda_saj
    Advanced Member
  • Members
  • PipPipPip
  • 1,153 posts
  • Name:sajeel
  • Car :honda accord
  • Locationlondon
Posted 24 May 2017 - 08:24 PM
Nice little mod I adjusted my cable from the accelerator position module to remove slack
Regards,
saj
